Serpentine set up
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
ntsqd
heratic car camper
Upper SoKA
Many times I've started out to do just that, go thru the front dress bolts bolt by bolt and develop a list of p/n's that I could order from. Each time something more important comes along and.....
Can buy the FSB's front cover bolts & studs from LMR, that solves most of those needs. Would be better if it were fully complete with all of the front dress bolts. Maybe just knowing that kit is available plus the couple other needed bolt's p/n's is enough?
M
Mclock
ARP 1541504
Viperwolf1
electron whisperer
If only there was a tech write-up to answer all these questions...
ntsqd
heratic car camper
Upper SoKA
ARP 1541504
Look at the LMR link, it is specific rather than generic.
In general SS hex heads are roughly SAE Grade 2 in strength. There are exceptions, but you aren't going to find them at a typical hardware store.
dmoses42
Bronco addict
Chatsworth, Ga
Ok, for ARP (you will end up with extras):
651-3250
651-4000
651-4250
651-1250
651-2250
651-2000
651-1750
200-8587 (need two kits)
dmoses42
Bronco addict
Chatsworth, Ga
Let me reassess... I thought I used Viper's post when I pulled my numbers, but when I just rechecked the numbers I posted, they are all 5/16-18. His post has 3/8 and 7/16 bolts for the brackets. Standby...
ntsqd
heratic car camper
Upper SoKA
I skimmed the article looking for p/n's for bolts, but I must have missed that section.
dmoses42
Bronco addict
Chatsworth, Ga
Ok, the numbers I listed are just for the water pump and timing cover. Let me look up the numbers for the accessory brackets....
toddz69
The 3 bolts for the driver's side bracket are 3/8". They are laying on my garage floor and my calipers were 2 feet away :).
Todd Z.
dmoses42
Bronco addict
Chatsworth, Ga
Ok, so the accessory bracket bolts are:
652-2750
652-4250
652-2250 or 2500, Viper's write up showed it as 3/8-16x2.375 but ARP makes them in 1/4 inch increments. So one will be 1/8 short, or 1/8 longer.
653-4250 (need 4, but Jegs shows it as discontinued? Would come as a pack of 5 if available.)
All the part numbers I listed come in blister packs (I think that's what they are called) with multiple bolts of the same size. And I didn't look up part numbers for the 3/8 and 7/16 washers.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
I'm thinking about going doing the explorer serp, does anyone know if the 94/95 SN95 timing cover/water pump is the same as the explorer? I currently have 95 Cobra front dress (I think its the same as GT) and am trying to figure out if I need everything or just the brackets/accessories
ntsqd
heratic car camper
Upper SoKA
I can't answer that, but in looking for a Stewart Components coolant pump for the Explorer it appeared to me that the late Mustang pump and the Explorer pump use the same casting. If they are not the same, they are remarkably similar. However, the fan hub is totally different. If the Mustang pump places the pulley in the location that the Explorer front dress requires that might open up some cooling fan options? That may be a dead-end, but I don't know of anyone who has explored it (no pun intended).
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Yeah, I'm mostly doing it to go to try out a mechanical fan. My Volvo fans are good but I think its time for a change. This is all mostly triggered by a small oil leak I saw coming from the balancer bolt area. I probably don't need to do the swap, but while we're "Exploring," I might as well lol
ntsqd
heratic car camper
Upper SoKA
A guy on an ancient yota 4x4 email list came up with the cleverest way to remove the front crank bolt that I've seen yet. Disable the ignition so that it can't start. Socket on the bolt, breaker bar with the handle resting on the driver's frame rail, extensions as needed for it to just sit there. Now bump the starter and watch that bolt spin loose. The nervous-nellies on the list were concerned for the radiator. I've never had even a close call, but an EB's radiator is in a slightly different location so caution is needed until proven to not be an problem.
I don't think the SN95 water pump has the threads for the fan clutch. You already have the pump, look at that. No threads, you can give up now.
