tworedballs
So I am inthe situation where my distributor has been pulled from teh engine completely. I have no marks as to where what was when it was running. My harmonic balancer is on correctly, so I have a set of marks as to what TDC is.
Now, I had my neighbor helping me today. We found TDC by removing the valve covers, watching the valves open and close. Once he saw both valves close, we then turned the crank 180-degrees and then tried to seat the distributor. I have played with the rotation of the distributor (I set the dizzy to hit the #1 piston when we put it back in) and all I can get it a backfire of sorts out of the carb like it is blowing gas.
Was I not supposed to turn the crank that extra 180 degrees? He had a book with him for rebuilding the Ford small block and it said to do that after finding both valves closed.
I know there has to be an easy way to get the engine timed enoght ostart if you don't have any marks for the new distributor. Help!!!?:? Thanks in advance, guys.
