- Mar 8, 2007
- 81,983
Oh lord. Spending all that refund $$$ ain't ya. U craxk me up
Nyles, good luck with the lift. I used cage f250 springs with bkg radius arms and a full width dana 44 high pinion. Dom steering and track bar with a steering arm from a f150 or f250 im not sure. The rear is a 5.5" spring pack with a 2" block and it's still to low to match the front. When I get my winch and bumper is should level out. Here's some pictures.
side view
Ohyea, tires are 38.5 boggers on 16.5 rims
3.5 in suspension lift
2 in body lift
37x12.50x15 Parnelli Jones Dirt gripz
2 in body lift
Im between you and Shamu on lift at 5", cut my fenders right and they will fit!
Anybody wanna cut on my glass?
Gallery, pic with Iroks.
Something like 3.65 backspacing
When I added the body lift and moved up to 37s it added more weight to the spare tire carrier. This along with the roll cage, back seat, toolbox full of tools and spare parts, recovery gear, ready welder, etc etc started to cause some rear spring sag over time.
I added some lift blocks to level it out. Ideally some 4.5 in rear springs are in order. If you're planning on carrying as much crap as I do, you might want to consider this from the get go.
Here's a side shot to give an idea of the fender trimming
whos flares did you use?
how many you got?
yea gonna charge your butt to pull you up da hill!
was waitin on you! how much lift you runnin?
3.5 WH suspension + 2" body + a lot of inner fender trimming.
