Small bearing 9"
bush450
Northern
Alright guys I am in the process of gathering parts for my rear end. I have the small bearing which I would love to upgrade to large. However I cannot swing the 4k+ to do so, so back to reality I have 4.88's and a detroit I want to ditch the detroit and put in a ARB the PO kept the 28 splines when he upgraded. So my question is, is the axle shafts the same from large bearing to small bearing? being if I upgrade later will I be able to use my 31 spline axle shafts and just replace retainer and bearings? or anyone in northern CA or Southern Oregon have used large bearing they are willing to part with lol.
rmk57
I can only say that I have a 57 ford with a small bearing axle and upgraded to 31 spline axles and they do make a conversion bearing for this purpose. 69-70 Boss, Cobra-jet Mustangs came with 31 spline small bearing axles.
I got all my stuff from Dutchman Motorsports, I think they moved to Idaho?
Rustytruck
The first thing i would check is if you bought the ARB in 28 spline could you buy the parts to change it to 31 spline later?. The bearing diameter on the axle shaft itself is different between big bearing and small bearings. Conversion bearings are there but extremely expensive. I think you would be better off leaving all as is and build or buy an axle assembly starting off with the housing you want. Your old axle assembly complete is worth a fair amount of coin and will help offset the costs involved. A stock open big bearing axle assembly is what 500 bucks or so. Your small bearing complete with Detroit maybe the same. The big issue is starting with a stripped big bearing housing if your planning to go disc brakes too. Then you may be better off using a new stripped housing.
If you were a fabricator cutting off the old small housing ends and welding on new ends is cost effective but your still stuck parting out and dealing with new brake assemblies too in addition to new axles and ARB.
Best bang for the buck is staying with high strength small bearing axles and 28 spline ARB. New axle steel will still be far stronger than Fords 40 year old axles with weak steel and fatigue in them. But new modern 31 spline axles are 30% stronger than the small diameter 28 spline axles. Really just depends on how deep are your pockets and how long do you want your Bronco down for and what type of terrain you planing to force your truck over.
SHX669
I'm not sure how they'll work for your purposes but TBPS has 31 spline small bearing axles for about $30 more than their 31 spline big bearing axles.
B
bush450
Northern
I haven't ordered the Arb yet just got some funds together I want to keep this under 3k. I would like to go 35 spline but that gets me to around $4500 and just under 4K if I went big bearing with new brakes and housing it isnt cheap. I am fine with drums for now, my big question is will the 31 spline shafts be the same shafts that a big bearing housing takes? And how reliable are those conversion bearings? I do run my truck not hitting huge jumps or anything but I use it.
Viperwolf1
electron whisperer
Axles are different between small and big bearing. Bearing inside diameter is different and brake offset length is different.
doghows72
Keep an eye out in the parts for sale. I remember a 44 front and a big bearing rear axle sold on here for like $500 each.
I bought a big bearing 9 off CL for $250. It was an open diff with 3:50 gears but didn't need any of that. Was really just after the housing.
I was having a hard time figuring out your numbers here and how just switching to big bearings would get you to $4k. Then I kept reading and figure you're meaning it's adding another few hundred to whatever total you're putting together. Whew! Was worried there for a minute you were getting the wrong quotes!
New ends are probably under 100 bucks and you can have them welded on pretty easily. Or get a new HD housing for 400, or buy a used one for $150 or so.
...so back to reality I have 4.88's and a detroit I want to ditch the detroit and put in a ARB the PO kept the 28 splines when he upgraded. So my question is, is the axle shafts the same from large bearing to small bearing? being if I upgrade later will I be able to use my 31 spline axle shafts and just replace retainer and bearings?
As they have already said. Nope. Not that simple.
I'll have one at some point. Just don't have it ready to pull out yet.
But if you're not going to be ready for awhile yet, keep me in mind. Though there might be others ahead of you if they still need it.
But other than less expensive bearings and the fact that yes, they're stronger, do you actually need the bigger bearings? The small ones were perfectly fine for normal use.
If you are going to be running big tires and pounding around off road with a load of camping gear, I can definitely see the upgrade necessity. But if you're going to be pounding around town with modest sized tires and not abusing it (much) then the small ones will serve you well for many years.
Or if you just want bigger stock drum brakes, that's an easier way to get them. Just factor in brakes no matter what, as they're different between big and small.
And speaking of brakes... If you're contemplating one of the rear disc kits like our $900 version that includes axle shafts, it's expensive but opting for the 35 spline axles is only about $100 more than the 31's.
What size tires and engine though? Most of us don't really need 35's. Just nice overkill, but not totally necessary.
I'm not trying to talk you out of all the good stuff and the big bearings, and I prefer them too, but just checking to see if you really need them.
broncnaz
Id put the ARB on the back burner and just get you a big bearing housing first you can either get a new one or used. Or a used fullsized housing and have it shortened although then your at about what a new housing would cost. But you would have the brake setup so it would put you ahead. You could recoup some money by selling the Detroit.
B
bush450
Northern
I run 35 13.50's right now the max size I will run is 37's nothing too crazy. But I don't have a light foot and will definitely be putting some power down in the future. So that solves my dilemma looks like I will hold off until I find something used or just buy one piece at a time. No reason to do it twice, I do like the 35 spline and realize they are not much more but I will also have to upgrade the case (3rd member) and run a aftermarket housing probably the route I will end up. Thanks guys for all your input
Maybe you don't consider them too crazy, but a 37" tire is actually a pretty big setup compared to what Ford ever considered for this axle. So yes, I agree totally to go with the big bearing ends. And too, since you are even considering 37's and have a heavy right foot, I would certainly opt for 35 spline axles right up front.
Would 31's handle the 37's? Sure, most of the time. But with lockers and spools (ARB's when locked) holding those 37's in line, I would sure upgrade to 35 spline axles if I had the choice.
Not because you must, but just because.
Have fun!
B
bush450
Northern
Absolutely agree, the 37's would just be used for snow tires aired down to single digits. But would also be a terrible time to snap a shaft I think I am gonna just hold off until I can swing it.
