Sniper to ProFlow Conversion shortcuts?
walker_creek
My Sniper (Version 1) failed at OCBR last year. After much research I decided to try the Edelbrock Pro-Flow 4. To their credit, Holley customer service was willing to give me a pretty good price break to upgrade to Version 2...but I wasn't sure it was enough of an upgrade.
So I'm finally ready to tackle this project. I'm thinking I've already done most of the hard work when I installed the Sniper.
Surely someone has already done this conversion. Any shortcuts/tips that might save me some time and/or frustration???
No idea, but I’ll be interested to hear how it goes.
What actually failed on the sniper? Just the typical computer issues, where it doesn’t run right? Or did it die an early death?
I know you’re probably documented it here already, but I didn’t remember the details.
73azbronco
I think considering short cuts, invites missing something.
Sure, you probably have good power supply, good fuel system, other than that, its a whole new ball game.
walker_creek
walker_creek
Computer fried. It ran acceptable for a couple of years, although never perfect. Had a low voltage issue and it started running horribly. Eventually the screen would go red (losing data) and the engine would die. That happened more and more frequently, then eventually the screen never recovered data and it won't start at all.
duffymahoney
Buying pre-built injector harnesses would save you some time and headache. I assume almost none of the sensors will swap over though.
walker_creek
walker_creek
The ProFlow has all the harnesses provided with the kit. I think I phrased it wrong..."shortcuts" aren't really what I'm looking for. I'm pretty anal about making sure things are correct. (A buddy that helps me gets frustrated because I usually take the extra time to polish or paint every bolt that goes back on!).
What I'm really looking for is:
1. Wiring that was already installed for the Sniper...are there good ways to utilize some of it for the ProFlow Install?
2. Where'd did people find was a good spot to install the ECU?
3. I bought the recommended fuel pressure regulator with vacuum connection. Where's a good place to mount that? Even better where's a good place to mount that considering I'm already plumbed for a Sniper, not starting from scratch with a carb.
I guess my question was really where to mount stuff and tricks/best routes for cabling.
Back to this, all I have to add, is that almost nothing is ever in the same place that you need it, when you change to a different type of product.
Yes, you occasionally get lucky and a wire or two falls near where you needed it. But it seems to me between two different systems, you’ll be lucky if wires fall in place, and practically a miracle if any of the fuel lines fall into place.
Heck, even the throttle linkage is likely to need some tweaking!😩
Maybe if some members show pictures of their current Pro Flow Install, you can see those and it’ll help visualize where you might need to mess with stuff.
Don’t ask questions from there.
Especially where to mount the ECU.
badandy73
Broncoholic
1. Guessing you haven't received many replies because the short answer is no. There's a slim chance of any cross compatibility between mfgs of the different systems. They will both need the same inputs (power, ground, cranking/key on power, ignition signal, etc.), but routing and harness layout will most likely be completely different.
2. The benefit of the Proflow is that the ECU is remote mounted, instead of the flawed location on the front of the sniper. Somewhere out of the way, dry, and away from heat would probably suffice.
3. Depending on how you ran your fuel supply/ return lines to the sniper, locating the regulator on the firewall somewhere they intersect would be ideal. I placed mine directly behind the intake up high where I have the fuel lines coming up the back of the bellhousing to what was the inlet/ outlet of the sniper.
Hope you have better luck with the Edelbrock than the Holley EFI..!
walker_creek
walker_creek
Thanks for the replies. Sooo.... Where is a good place to mount the ECU?
What about the location for the fuel pressure regulator? (I bought the one they recommended that has the vac line connected)
Fronkmc
I switched from sniper to the pro flow 4. I continued to use the inline fuel pump (the pressure rating was high enough). That was the only part retained. I put the ecu on the kick panel on the clove compartment side to keep it cooler than the engine bay. Placed the fuel regulator on the firewall behind the manifold. I have had great results with this system over the sniper. Three years in and no issues. Make sure the unit is very well grounded. I put extra ground cables from battery to engine to chassis. very important.
walker_creek
walker_creek
Thanks for the input! I'm assuming the harness was plenty long to get the ECU inside the cab?
walker_creek
walker_creek
Work keeps getting in the way of Bronco progress, but I finally have the manifold test fitted in now. When I did the Sniper conversion, I bought a fuel line kit from BC Broncos. So my current fuel lines come up behind the engine, in the center of the engine bay.
The Edelbrock Pro-Flow 4 has the fuel inlet plumbed to the front of the passenger side fuel rail. That's probably a really good spot for an original carb conversion. I think I can keep this install so much cleaner if I bring my fuel lines in from the rear again. To me it looks like I can replumb the rails and put the crossover line in front, and move the intake, fuel pressure sensor, etc. to the back.
Can anybody tell me if this is OK? I want to make sure I'm not causing myself unforeseen problems by doing this.
walker_creek
walker_creek
Found a post on Edelbrock forums. Looks like it shouldn't be a problem to change it around!
walker_creek
walker_creek
Had a delay in this project...for some reason last week I thought I needed to drag a barely running rust bucket '78 Bronco home from an estate auction.
But I'm back to it now. I mounted the fuel regulator where badandy73 suggested. I bought a nutsert tool first so I can remove/replace it easy. I think that's going to work well.
I was putting my plug/coil wires on last night. I realized the fuel rails don't allow for the normal coil mounting location. Anybody found any good, clean looking mounting solutions for the Pro-Flow?
BTW...after getting all the old plug wires out of the rig and in bright sunlight I found a short/burnt spot on the #4 plug wire. I'm wondering if this high voltage short is the culprit of the Sniper failure? Definitely a possibility.
Helijeff
Thousand Oaks
not sure if this will help or not
walker_creek
walker_creek
Thanks. That's pretty similar to what I ended up with, except I mounted the coil vertical.
Every coil manufacturer that I know of recommends a vertical mounting. The original Ford coils were built to higher standard, according to some, and could handle the angle or flat mounting that many came in.
The good news about that horizontal mounting above, is that it is a direct line to the cooling fan action. Probably be fine in that case.
Just remember the old warning. Don’t leave the key in the ON position without the engine running! :)
