Not sure about the OP, but the main reason is to make it more responsive and cooperative with any modifications. Even better breathing exhaust can sometimes throw Ford SD a little bit of a curve, but cams and other stuff are just not going to make it happy. Aftermarket SD systems (most of them out there) don't care about that stuff. But factory SD is not mod-friendly.
I seem to remember it's a little less responsive to major changes in altitude under modified conditions too, but it's been so long since we've talked about Speed Density I might be making that up in my head.;D
That what you have in mind Punisher? Or are you just doing it to do it?
If so, and you're just running stock, or fairly stock stuff, nothing wrong with SD.
So I guess I'm going to look for a computer and some injectors. Then just add some wire.
The throttle body is smaller than a 86-93 5.0 mustang as well. You will need to do some re-pin work, add VSS wires, add pin 19 (Fuel Pump monitor) circuit, add a second O2 sensor. You will also convert the MAP sensor to BAP sensor by removing and blocking the vacuum line on the engine side.
It's pretty easy to do, but that motor will need a lot of work before you see a benefit. This change will not help your motor unless you change heads and cam. You may find that converting to an explorer motor and computer will save you some dough, while returning respectable performance.
What do you mean by a second 02 sensor? I have one after each exhaust manifold now. I would need another?
