COBlu77
Bigger $$ than that Just how often will you NEED 10.34?
I have yet found a need...I do have a auto;D
Cary
I took the cheap and easy way out for now with an NP205, but when I talked to AA and others with auto trannys, I was told that anything lower than 3.8:1would be an issue. Normal brakes would not be able to hold it from creeping and you'd have to shift it into neutral. AA said I'd be happiest over all with 3.0:1 and a 4R70W, unless I was doing extreme rock crawling. Miley pulled his brake pads off trying to hold back his Cummin's powered Bronco in low range with his 3.8:1 Atlas and hydroboosted brakes.
