CopperBronco
- Joined
- Aug 13, 2021
- Messages
- 389
My Bronco is having problems starting after having it sit, it can do this normally especially after sitting for 4-5 days. This is the first time I can’t get it to truly start though… Here's my setup:
302 V8, 2brl Carb, electronic ignition, not the old points, have a 3G alternator, high torque mini starter, brand new optima red top agm battery last month as old one was dying, testing at 12.5 volts at battery and relay after cranking on it a bit. 11.7 volts at old style 70s fuse box… this has been typical while I’ve had it… and often starts no problem.
New taylor spark plug wires as of last year each wire with .01 resistance. I have grounds from battery to engine block to the frame. Also lots of other grounds all around the Bronco. I've been through most of them and cleaned them up not too long ago as I want to avoid gremlins. I've also lightly sanded and cleaned the inside top metal point of the distributor to remove carbon build up which I had some.
When I go to start my Bronco, it'll turn over nice and fast from the starter, but just won't start. Engine fan will start to turn… Sometimes I end up flooding it like last night. It started briefly but then couldn't sustain and of course I couldn't give it gas as it already had too much, I let it sit over night to get rid of flooding, but still won't start.
Hooked up remote starter and ran inline spark plug test… got spark, but longer I ran starter weaker the spark got… wondering if plugs are wet… how long does it take those to dry? I’d rather not pull them all out manually… spark plugs are newer as well if I recall right… replaced a yr ago…
Would love any advice or diagnostics I should run.
