Steering box
Mommas75bronco$
Replacing steering shaft and steering box in my 75 bronco ordered a borgeson box and shaft from CJ Pony parts and the shaft won't bolt up to new box the shaft says 73 to 75 bronco bolts right up up to old steering box though I called CJ pony and they said they only carry the 1 borgeson box any suggestions
So you’re saying the diameter and spline count of the shaft yoke does not match the input shaft of the new box?
That would not have been surprising with all of the other boxes on the market, and maybe even the Borgeson ones went through changes over the years, but I haven’t heard of any changes lately.
What type of lower shaft is it? Stock replacement, or one of the shiny aftermarket ones? Borgeson brand joints, or flaming river? Or maybe another?
RH
The borgeson input shaft is larger then the stock ford input shaft
You said you got a box and shaft. The two parts you ordered, are they the ones that don't mate? Not sure why you are trying to mate a stock ford shaft to the Borgeson box when you stated you got a new shaft with the new box.
Jdgephar
Manual Bronco box is 3/4"-36 spline
Power Bronco box is 13/16"-36 spline
The Borgeson box I have is 11/16"-36 spline on the input.
Sent from my SM-G981U using Tapatalk
