Steering gear identification
Teal68
Inlet Beach
I need you guys help again already! I have a 67 that I'm piecing together from many Broncos and Bronco parts I've gathered over the years. I bought a used OEM power steering Bronco set up from a member years ago. Years ago! I just installed it about 6 months ago, and the input seal was leaking slightly. Now it's puking. No big deal...It's been sitting a long time. I bought an input seal kit from the local auto parts store and when I went to install the parts today I noticed all the parts were too small. After that, I checked with the parts store to make sure I got the right parts kit. It checked out. Either the parts kit I got is packaged wrong or I don't actually have a Bronco steering box. All the parts that came out of the box are larger diameter than what came out of the re-seal kit I have.
See attached images. if it matters, it about a 5 point something or 6 turn box is what it takes stop to stop..
Images:
-The IPC number is the seal that was in the steering gear box and dimensions
-The comparison pic has the seal kit on the bottom and the actual box parts above
-Steering gear pics from above and side.
Are there numbers somewhere to id the box?
Your help is much appreciated. I want to take this to Throwback so bad!
Teal68
Teal68
Inlet Beach
No luck at the parts store. Same parts in the kit they had on the shelf.
Starting to feel like even though this looks like a Bronco steering box it most likely came out of something else.
Slowleak
Georgia
It sure looks like a bronco box. I replaced the input seals in mine a few years ago and had no problem finding them locally. Here’s some stuff that may help identify it….but it looks pretty obvious. I have a 77 box I just pulled out. If you want me to measure anything let me know.
Teal68
Teal68
Inlet Beach
[/URL]
Yea, I did some more digging and I feel more confident. The local kits have seals that are for a 3/4" shaft. We're supposed to be leaving for Throwback next Sunday. I hope I have it resolved by then. You going?
Slowleak
Georgia
I am…. Checking in on Wednesday. I’ll see you there!
Viperwolf1
electron whisperer
The input shaft size and spline count changed on most saginaw boxes around 1976. It didn't affect the Bronco boxes. You just need to source an older kit.
Teal68
Teal68
Inlet Beach
Thanks Viper. Yea, I feel like there system is wrong and it's giving me a kit for truck box. Would that be the Edelmann 7858 I noticed you referenced in another thread?
Viperwolf1
electron whisperer
That's the full seal kit for a Bronco box or really for any small piston Saginaw box from mid 60s to mid 70s. Those all had the large input shaft.
bronco217
This is the one I used a few weeks ago for mine, from O'Reillys.
Precision Power Steering Steering Gear Seal Kit - 28401078​
Teal68
Teal68
Inlet Beach
I'd prefer to just get the input seal kit, but the lack of detailed information on Rockauto has me concerned. Especially since Sunsong has basically the same part number as the kit I got that didn't fit. At least it says 3/4. Which I guess means 3/4" diameter shaft. The Edelmann 7095 gives no detailed information at all.
Link to Rockauto:
https://www.rockauto.com/en/catalog...,steering,steering+gear+input+shaft+seal,7353
Teal68
Teal68
Inlet Beach
Thank you. I may to get the full kit. Good to know that one works.
I missed that and it was listed right there with the part! I am not a master of the obvious! Thank you
EDIT: Now I see you used a different vehicle to come up with that part number.
Teal68
Teal68
Inlet Beach
Update for future reference:
Edelmann 7095 is a correct input seal kit for our Bronco power steering gear.
Edit: Corrected part number. Thank you pollack77 for catching that.
