Ok, you do have a dropped pitman arm, but not a matching lowering bracket or riser for the trackbar. On a pre-'76 Bronco, that's an almost absolute requirement. Only exceptions are if you have other custom mods or TRO or other things where one does not necessarily have to coincide with the other.
I see you have an adjustable trackbar, which is good, but it's only there to help center the axle. Has no effect on the angle of the dangle, and that's what's even more important.
So, add a drop, or better yet, a riser bracket to help get your trackbar more parallel with your draglink.
Don't know why it should, but that just looks like more than 4" of lift. The angles on the steering links are pretty steep for having a dropped pitman arm. Still, I'll trust your 11" measurement as that's going to be more accurate than just looking at an image on the computer.
Shallower angles are important too of course, but parallel angles are more important. Especially while you have your stock draglink and trackbar lengths relatively intact.
