Stop/Haz Switch Problem
JaxLax
Jacksonville, FL
First I have installed a Centech Harness and this is the latest gremlin to appear. (PS was working fine til i installed the radio?) But now I have nothing. Here's the lowdown: With the ignition off: w/o fuse in, getting 0 volts @ fuse box. w/fuse in getting 12.25 volts at the flasher (took out and put in prongs of volt meter). With the power on: w/o fuse: still getting a 0 volt charge. w/ fuse in (again measurement taken @ flasher unit) got a 11.72 volt drop. with it off and the fuse in pulled hazard and charge went from 11.72 to 11.70 volts (w/o flasher unit and the fuse in). again without flasher and with fuse, pushed brakes and volt drop went from 11.72 to 11.50. But as soon as i put both on at same time (with ignition in off position) fuse blows immediately... (haven't tried installing both after ignition is on, just feel this is a BAD idea) basically does this mean I need a new flasher unit? Should i try and switch the ones i have now and see what happens? Or is there something else that i am missing? sorry about being so long winded, just thought it was better the more info i gave.
Thanks in advance for any help - matt
stevew
Elliston Montana
What did you do with the "extra" wires for a dash mounted flasher ? Centech is set up for either a dash unit ( early ) or the later steering column flasher . If you don't seriously tape or cut off & tape those extra leads you'll get problems . I've never had a major problem by simply following exactly the set up instructions in 7 Centech installs .
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
Use your ohmmeter on the flasher testing between each prong and the housing. If there's continuity then replace it. If not, the flasher is not causing a short. This won't tell you if the flasher works, it is just a test for a shorted circuit.
JaxLax
JaxLax
Jacksonville, FL
SteveW That was right on. I got back undre there and taped them off, and it's perfect now. I guess when the radio went in all the open connectors were touching the metal casing.
Thanks again! -matt
