suspension mods
rookie builder
trying to build an all around suspension. what would be the best the standard coils or coil overs. I want super responsive suspension that can soak up pot holes at high speeds, and ride good on the street.
TN1776
The answer depends a lot on how extreme (read, how far from stock) you are planning to build your rig. I am not aware of any direct bolt-on coilovers for the EB and the ones I've seen in use require some extensive bracing between sides as the shock is now also supporting weight in addition to dampening the bumps.
I would talk to the major vendors about the different coils they offer (pre-runner vs rock-crawler) and see what they recommend. It doesn't sound like you're looking for an increase in articulation like many guys on this site build their suspension for. I'm sure somebody on this site can point you to more in-depth technical suspension info.
If you do go the coilover route... take lots of pictures!
garberz
Bronco Influencer
Conejo Valley, Ca.
If you want something that handles well on the street, then stay away from a coil over set-up. I would suggest 2 1/2 to 3 1/2'' lift. Prerunner coils with extended radius arms. Bilstien 7100 , F-250 shock towers, 10 or 11 pack rear leafs. Bilstien 5100 or 7100 for rear shocks, with an inboard hoop mount.
This would be a good semi-budget all around high speed suspension set up.
74BroncoCO
I would start by calling BC Broncos. Chuck runs a bronco on the baja 1000 and could point you down the right path.
J.D.
SteveL
Huge chevy guy
Hawthorne ca
stay away from the inboard hoop in the rear if you want good on road manners. The extended arms also add body roll. I've heard BC's WAH handles better on the road. I have one in the garage almost together for our 66, then I will know for sure. The 66 is the wifes' DD and she doesn't want it to handle like mine. My other bronco has an inboard hoop and extended arms. It gets a good amount of body roll on the road. The inboard hoop works great off road but I'm putting mount's outside of the frame to get some better street manners. I think the radius arm roll can be solved with stiffer shocks up front.
chuck
Ingram, Texas
I ran my 4.5" coils on the racer for 4 years(yes the same set), they held up great and gave a good ride stable ride with the WAH and King triple pass shocks for 2 years even at higher speeds. I went to a 9-44 and do not have a WAH for it. Last year I sheared the spring bucket off even with the top of the frame so gave the coils to George and installed King coilovers. I hope the guy above is wrong about them not being good at high speed. I can't say as I have had nothing but trouble with the install (3X16), seems King doesn't have coils light enough for the EB so I am having my own made now. Hope to be driving in about a week.
