Suspension Mods
EricLar80
What is the consensus for what is the best upgrades to make on the suspension without cutting up the inner fenders? I am familiar with the F250 shock mount and hoops, obviously, but are there shorter coilover systems that would be worthwhile? Or, is just updating the shocks from Rancho 9000s something modern enough?
I am willing to remove/update the shock and coil mounting system to bring this suspension up to modern standards, but don't really want to get crazy with removing the entire inner fender.
I really would like the ability to hit the sand dunes at speed without knocking out teeth, but I don't need to jump it. I would like to it to keep good on-road manners for when my son eventually drives it.
Willing to consider higher cost options if the benefits outweigh the cost.
I appreciate any input you guys have to offer.
SteveL
Huge chevy guy
Hawthorne ca
For off the shelf I would get hold of monster mike at duffs. They hAve a pretty wide variety of options for suspension set ups. Hitting the dunes hard you might need the strength of shock hoops up front over the f-250mount. With that said if you want sway bars for street driving most front hoops dont clear for sway bars. Check out bloody knuckle front hoops for clearance in front of the coil. If you get into the coil over stuff most end up cutting the inner fenders front and rear to make it worth doing.
rguest3
If you want to go with Coil-Overs up front - Ruff Stuff 12" Coil-Over Towers and Paired Shock Flat Mount for the Lower Coil-Over mounts - These will replace the Bronco factory Coil Tower and the Shock Tower. The RS 12" Towers will need a 1-2 Body lift. Maybe, Maybe the very bottom of the inner fender will need to be trimmed depending on body lift. The Towers angle out as they go up. Coil-Over of your choice probably in the 10-12" Range.
The JD Dual Sport 4-Link Rear is very nice too.
EPB72
Pleasant Hill, CA
the ruff stuff towers option was the first thing a thought of when he mentioned coil overs....
Dunes at speed will take a little higher spring rate than the typical super soft springs we tend to love. If you can fit a set of air bumps to calm that bottom out it would be great. Even the factory Jeep Mojave is getting those. The poor mans solution is a set of microcellular bump stops (the yellow/orange greasy, feels like a dense foam) found on a lot of newer vehicles.
For a long time a set of Bils were the go to answer, but there are better solutions out now. I'm trying to remember the name of the suspension shop in AZ that has good stuff. I'll just throw the generic Fox 2.0s as an option.
There is a lot more radially available go fast suspension parts out these days. Even 5 years ago is was rather unknown and highly specialized. But getting on the edge of mainstream. My daily driver just got upgraded (well over a year ago now) with 60mm Bilsteins (over the standard 46mm) and remote reservoir rears. And they were an off the shelf set, nothing special built about them. Instructions were model specific. I haul ass a lot faster on forest service roads now, because it works and I have better control over what was factory (that was a factory upgraded Bilstein package as well)
rguest3
OP is looking for good road manners as well, so nothing too extreme with a compromise for dual purpose.
I think it can be done with fairly stock style suspension. The evolution of suspension is starting to shift that direction. The super slinky max articulation stuff isn't as popular as it once was and people are doing a lot more road driving and demanding better manors out of it.
lars
Been here awhile
NorCal flatlands
Eric, I've been running 12" stroke Fox 2" monotube reservoir shocks with 7/8" shafts for close to 15 years now. I called raceshock.com in PHX and explained to Lee Finke (owner) what I wanted to do, namely good compliance at speed using only one shock. He built them and valved them for me.
Upper mounts are hoops of my own design. Though that latter detail doesn't really matter, all I was after was getting the mounts as high as possible with the same goal: no fenderwell cutting.
Lower mounts are on my own radius arms but they are the stock location.
Springs are WH progressives, nominal 3-1/2" lift.
The important part was the shocks. I posted something the other day on a thread here about single vs dual front shocks. I could not believe how much of a difference a decent single gas charged monotube shock made over the Ranchos I had before. The first few times I encountered big whoops on some of the roads I habituate in the basin & range country I braced for impacts that never came. Worth noting is that decent on road manners are essential to me. I will sometimes put 1500+ miles on during a single outing.
That said, I've wished for gas bumps as mentioned by others for some time. I'm using the squishy foam bumps for now, but one of these days I'll upgrade.
Figure out how much room you have for a shock going as high into the inner fender as you are comfortable with, pick or make an upper mount of your choice. I'll say call Lee at raceshock.com and tell him what you are doing, but there are other talented shock folks too. Pick a remote reservoir gas charged monotube shock brand. Brand choice is good for endless debates. All are better than standard double wall shocks. Install. Smile when you experience the difference.
E
EricLar80
Any chance you could post a picture of your hoops? I have been contemplating a hoop setup of some sort that would take advantage of all the space available - one that would put the mounting bolt right beneath the inner fender. I kinda like the single-shock hoop that goes for half of the fender length and attaches one end to the spring bucket. I have a 1" body lift and will likely keep it since it seems to help with fitting the drivetrain.
Based on everybody's feedback, it sounds like gas bump stops are a must, which is good to know because I wasn't really thinking about them specifically. Before I order shocks, I guess I need to fab up the mounting system so I know how much room I have available.
Do I also need to know the final weight of my rig to order some 2.0 shocks?
Does it make sense to go with a longer coil spring (i.e. - change the spring bucket height) so the rate is more consistent?
lars
Been here awhile
NorCal flatlands
I can get some pix later this afternoon. I kinda got carried away with the upper mount tab design as well, I have some pix of that that I can share. Also, after a few r&r's for shock rebuild (15 years of use will do that) I got tired of groveling so I actually did cut into my inner fenderwells. Specifically I cut a rectangular hole directly above the mount tabs, then fabbed aluminum covers that are bolted over the holes. Much more civilized access.
I can see the argument for a longer spring, though I never did that. I'm sure others can weigh in on that. If you are going with hoops, now would be the time.
Couldn't hurt to have the weight. It's been so many years that I can't remember if I supplied that number or not.
toddz69
Mark Davis (garberz) changed his spring bucket height. He's a good one to ask about that mod.
I'll also second Lars' recommendations. His truck and mine are set up very similarly - and not by accident.
Todd Z.
E
EricLar80
Todd Z.
I live near Mark; I will have to pick his brain on it. I am taking the body off the frame, everything else has been stripped, so now is the time to do any of this.
E
EricLar80
Haha! You said "consensus" on a Bronco forum.:eek:
I don't thing we see something resembling a consensus about anything to do with Broncos very often here.%)
Funny thing is I knew this when typing it out! But, I figured we always learn something so may as well ask anyways. ;D
So what about using a sway bar or two? What does everyone feel about this. For the above usage, not the crawly stuff.
lars
Been here awhile
NorCal flatlands
Pix? What pix?
Dropped the ball. Passed through my Bronco storage zone, AKA my hangar, this afternoon on my way home from work, but as usual painted myself into a corner timewise. Tomorrow. Really and truly.
E
EricLar80
No big deal. I’ve got time to wait at this point. I appreciate you checking back in.
bchesley
I am in the same camp as Todd and Lars but I am running the Protofab/Wild Horses extreme rear mounts and front hoops with fox 12" 2.0's. I had them custom valved by off-road warehouse.
I bent and partially tore loose an F250 mount in the front hitting some small whoops and jumps before I switched to the front hoop. The rear setup does have you cutting the rear fenders out and welding in some new covers, but the body roll that the higher mounted shocks eliminated was so worth it. My road manners are fantastic now at 3.5 inches of lift. I wouldn't hesitate to do it again as I didn't really lose any rear space.
