My suspension Mods, will they work
74BroncoCO
First off, I just wanted to make clear that I am working on a very tight budget and even these simple upgrades are going to happen in phases as the money allows, but I wanted to see what you guys thought and if you think it'll work well.
Where I am now: This is a rock crawler that gets to the trail on the back of my trailer. I have 2" Suspension lift and 2" body lift. The suspension is F-150 front coils and 2" Add-a-leaf in the rear. Yeah pretty stiff!! I have poly bushing on the front and stock radius arms.
Phase one: I will be getting my hands on some used rear leaf spring pivots and that adds 2"+ of lift and a lot of flex. I am using the stock shock mounts now, so I want to go with the adjustabele inboard shock mount and hope that my current shocks will fit on it. On the front I need to level my bronco probably with some spacers (cheap way). Then I might build some brackets that will bolt onto my radius arm and turn the shock 90* to try to elminate some of the bind.
Phase two: I would like to weld the F-250 front shock towers in and get longer shocks. Then get longer shocks for the rear to allow for more travel, and stiffer to control body roll. Then get some new coil springs to help loosen the front up some as well as be able to get rid of the spacers.
Phase Three: See if I can run 34-35" tires!
Someday I'll do something with my radius arms.
Thanks for your opinions!
J.D.
TJK74
Newark CA
J.D.
Not sure how much the spring rockers are going to help you out with flex if your rear spring are like you stated (stiff). As for your spacers up front. i think I would save some money and just get the propper spring you need. (just sounds a whole lot safer) You can get a good set of spring for a $120- $160 depending on the vendor. One thing you can do which is cheap and easy is to add some rubber radius arm bushing. they take alot of bind out of the front end versus poly bushings.
I don't think you are going to gain much. Looks like you wil still have the same old stiff springs.
Fancy shock bracketery probably woun't gain you much of anything. try taking the shocks off completely and see what it does. The improved shock mounts will help once you soften out the springs.
Being that you are on a budget, my recomendations are to find a nice set of soft front springs. Front coils are fairly cheap at only $100. Don't waste your time with the rear rockers. Take your existing rear springs, remove a few leaves to soften them up and have a local spring shop re-arc them. Stock springs actually flex fairly well.
Once you get the springs to actually start moving, then worry about the shock mounts.
If you look at the picture in the avitor to the left of theis post you will see a bronco that has a set of soft springs and all the original shock mounts. none of that ramp-trickery pivot stuff.
crab
Just my opinion.............
I would not install the rear rockers. Results would be a lot more expensive then a suspention lift unless you don't value your body, both yours and your bronco's. Coild shims are a waste of time and money. You will only get an inch of lift out of them (been there). If you just want a cheap lift, look on ebay, the rancho springs pop up and they are a decent lift spring, just don't have any flex, but more then your stock spring with a shim, and sell around 30-50 bucks. Do a shackle flip in the rear not an add a leaf/rocker.
Your gona do what you have to to get those 35's under there and you know it. Just hack out the fenders and call it good ;D
Good call on the shackle flip. I have seen those work good on other vehicles, forgot about using it on a Bronco. Just make sure you find a way to prevent the spring from going overcenter and returning to the original position. That and pulling that stiff add-a-leaf (and maybe another leaf as well) should do wonders for a cheap lift in the back. It should also keep the pinion angle decent as well.
Somehow we will get you a decent working suspension on a tight budget.
74BroncoCO
Darn! I really had my heart set on those spring pivots, but only if I would gain some descent flex. I had thought about a shackle flip a while back, but I forgotten what they look like. I'll have to research that one! Really for front flex, I can't complain. It's not monsterous, but it's respecable. I have never seen them, but the front spacers I was talking about are a puck style that bolts below the spring. This is what a friend told me anyway???
I'm not really looking for lift as much as flex right now, but at some point I could use those two extra inches. My rear fenders need trimmed a lot more, but I do have some trimming done already and my 33's don't even come close to hitting them. I do have problems up front at the very front of the fender.
By taking out my AAL and another leaf, then re-arching I will still have 2" of lift from them? I knew you could re-arch them, but I didn't know they could be arched enough to gain height. That's a thought! And I could probably ofset the cost a bit by selling some of the stuff I already have.
back on the pivots; just so we are on the same page, this is what I had in mind: http://www.bcbroncos.com/pivot2.gif. Can someone explain why I wouldn't gain much from them? My observations with a leaf sprung axle at full flex is trying to twist the leafs out of the mounts and this would aleviate that and allow for more? Is there something I am overlooking? Thanks for your help!
J.D.
broncnaz
I agree with the others here search(ebay, Classifieds here) for some good springs before getting axle pivots. a good set of springs will get you more flex than your old springs and axle pivots. Also considering that your looking at about 4+ in of lift your probably going to need new driveshafts and longer brake lines. cheaper is not always cheaper especailly if your going to get the correct parts later on do it right once it will save you money and keep you driving your EB instead of wrenching on it.
