Suspension mods
G
Guest
Guest
I'm building my friends dad's bronco for him and he wants "nothing but the best" So I got him the currie hi-pinion axles, the moon eyes gauges, the built 302, the racing seats, and on the way an NP4500 and atlas II 4.3. Now for the suspension we're getting Deaver leafs in the rear but on the front I'm not sure what to do. I know Jeeps but not Broncos. We have the James duff OTK steering conversion W/ disk brakes and James Duff supreme power steering conversion w/ drop and stock pitman arms. We're looking to clear 35" tires w/ the least lift, least fender trimming, and the most flex. It already has a 2" body lift. I like the J Duff radius arms but are there better ones out there? What should I do w/ the track bar? I want a heavy duty adjustable one but who makes one? Should I also get a drop bracket for it? J Duff shock hoops look good too. Any objections? And then the coils.... We can pay out the nose for some deaver customs but there are some nice ones at..... ya JD again. And fox 2.0 or 2.5 resiviored shox are going with all this. Thanx for all your help.
Garrett D
broncobsession
WOW, I want pics ;)
To answer your questions: BC Broncos 3.5" coils. Performance unlimited steering and track bar (you won't need a drop bracket because they can build them to any length I believe). JD shock hoops should work well and since you already have the 2" body lift they will fit well.
BTW, it's not too late to throw that 302 in the garbage and build up a 351W instead.
EDIT: I assume by JD you are talking about James Duff, right? I agree with Teknalee...National leafs are great and they made sizes from stock to 5.5" lift for Broncos. I bet it would save some money (if your friend cares about saving $).
Dusty
Hey guys don't wave him off the Deaver leaves so quickly. Deaver knows their stuff, and while I don't think they would be all that Bronco-specific in their expertise, they do understand how to custom tailor a spring to a vehicle. They're a good outfit. Besides, I'm not sure if this is still the case but I believe Deaver used to start with National leaf blanks to build their spring packs.
Garrett, as for front coils, BC Broncos no question.
Dusty
Dusty
For radius arms, you might want to check out West Coast Broncos in Yucca Valley. They make a nice pair that enable gobs of flex. If its SICK flex you want, you might consider the Wrist Axle Housing (WAH) from BC Broncos instead of custom radius arms. I believe BC Broncos also now has a custom heavy track bar that uses johnny joints or heims or such. Matter of fact, just give Chuck at BC a call and he'll fix you up with everything you need.
Also you should have passed on the Currie Hi-pinion 9. I like Currie stuff, but the hi 9 uses an 8.8 ring gear. Still probably plenty strong, but EBs are heavier than jeeps and I don't think the extra clearance justifies it. The EB is longer than a jeep and can handle the driveline angles of extreme flex even with a regular 9". Should have put that money into a nodular case, spool and 35-spline axles.
With that 2" body lift, you can clear those 35" tires with a 3.5" lift. But you'll need to cut and flare the front and rear fenders if they're not already. Also, take a BFH and beat down the body seams inside the fender wells. I've got some custom vertical siping on my BFGs that I didn't want.
Good luck, this sounds like an awesome buildup. Tell your freinds dad to join up with So Cal Broncos if he wants to hit the trails with a great bunch of EB fanatics.
Dusty
G
Guest
Guest
Thank you all for your help keep it coming! I considered the National leafs and they may still be an option. Are they triple military wrapped like Deavers? As for the Performance Unlimited steering it's too late because we already have tie-rod and draglink from James Duff. I also like the idea of the custom hiem jointed track bar from West Coast Broncos. We've already dumped too much $$$$ into the 302 to change it. (Electric fuel pump, Elec. water pump, Holley truck avenger carb, Edelbrock performer RPM intake manifold, Hooker super comp ceramic coated headers, ARP bolts on everything, Cast aluminum timing chain cover, electric fan on auto t-stat switch, MSD 6 off-road coil ignition box and rev. limiter, MSD wires, MSD distibutor, K+N 14"x3" filter and lid, UNI pre wrap, Optima yellow top battery, Powermaster 200 amp alternator and more to come) THIS IS A DREAM COME TRUE!!!!! The goal here is not all flex, it's about travel for high speed stuff and it will have the skidplates to rock crawl. And if it flexes good to the all the better. It's going to be street driven so no spool. In the rear we got a Hi-pinion 9" w/ 31 spline ARB and explorer 8.8 discks and a skidplate. Front is Hi-pinion D-44 w/ 30 spline ARB warn outers was Avalanche now Poison Spyder Customs rock ring. Well that's all the bragging for now. Wipe up the drool and keep the advice coming! And by JD I mean James Duff
Garrett D
Hnrys69
Ummmm.... ditch the hunk O junk carb and go EFI or with a BC carb..... I would call BC before you spend another dime on this thingy. If its not yours make sure you do it right the first time for sure!!!!
Dusty
[quote author=Garrett D link=board=5;threadid=16308;start=0#msg124171 date=1050215468]
[/quote]
I think you can use everything you listed on a 351 with the exception of the intake manifold, which if this truly was to be the "super Bronco", it would be fuel injected anyhow :)
When you're done let me know. I happen to think mine is set up pretty well for high speed sand wash racing and pole line roads. We can take them out to Ocotillo Wells for a hot lap through San Felipe wash.
Dusty
77BroncoWag
[quote author=Garrett D link=board=5;threadid=16308;start=0#msg124134 date=1050205815]
[/quote]
Not on this planet ;D
G
Guest
Guest
Dusty,
I know a 351 EFI is the way to go but we couldn't talk him into it or even EFI on the 302. I think the Holley Truck Avenger should be fine. It can operate at angles the bronco can't take w/o rolling :) And we're almost done w/ the engine anyway.
Does anyone have a phone number or web adress to West Coast Broncos in Yucca Valley? And I like the WIld Horses rear extreme shock mount. The only problem is that he might not like that extra bubble in the back there. Can I get a thumbs up or down on that? And someone said the James Duff front shock hoops are fine but who makes "The Best"? Thanks again for all your help.
Garrett D
Dusty
The "BEST" front shock hoop is one you fabricate yourself. Since you're going with custom radius arms and fancy shocks (res shocks have a longer shock body than your plain old shocks and require more room), you should do it right and fab your own hoops. Cut out the inner fenders to make the upper mounts as high as you need them. Put the truck on stands with the springs out and cycle the suspension to find its true extremities then choose your shocks and fab the mounts to accomodate it. When I was building my Bronco, I bought the Wild Horses "Extreme" hoops. I got the gas axe out and torched them off the following day and made my own. But if you insist on going store-bought, either the WH or the Duff's should be fine. See if either of them are capable of being mounted higher to take advantage of your body lift.
For the rear shocks, you can get long travel capability without hacking the tub by using the inboard shock hoop that BC Broncos sells. I like the WH setup better from a performance standpoint though, but as with the fronts, I don't know whether you'll be able to fit the shocks you want to run without doing something custom in the rear too.
West Coast Broncos phone number is (760) 369-4126. John Blazer is the owner (kind of ironic name eh?). I know there is information about them available on the web but I don't think they have a real website. Do a google search and it should turn up something. A lot of the LA guys swear by West Coast Broncos.
Too bad about the 302. I guess your freinds dad just wants to be an also ran. That's cool. There's plenty of room on the porch for the little dogs :)
Dusty
