Swerving enough to concern me
Cool67
Bought this 74 Bronco in January. PO had not used it much lately but did stick quite a bit of money in it previously. Been doing small things since then and took it for it’s first (about 5 mile trip ) since I bought it. I know these are not like driving anything newer but I am somewhat concerned that it is swearving back and forth ,more so at slower speeds like under 40 mph .I did ( even before my test run ) install a new steering stabilizer shock from WH. The main steering rod that runs to both spindles looks very new .3 of the ball joints look very good ,1 not as good. Everything up front is very tight when tugged at….Where should a guy start? Or is this just the nature of the beast. Tires are old….but are aired up equally but who knows if they were ever balanced? Any help would be most appreciated.
Yeller
Rogers County Oklahoma
Ball joints, radius arm bushings, track bar bushings, and leaf spring bushings are huge factors. One thing that we find really helpful is getting the alignment checked and get them to provide a print out and post it here. That will expose any unseen issues that can be difficult to measure.
I would start with getting an alignment check. What caster and toe. New steering but never set the toe could make things sketchy. Lift and never corrected the caster, that is bad as well.
SteveL
Huge chevy guy
Hawthorne ca
Assuming it's got ps being a 74. Did you try it before putting on the new stabilizer on? Tire size? Track bar bushings are the first place I look if mine starts handling funny. With the motor off have someone turn the wheel back and forth.while they're doing it check from the upper steering shaft to the tires for loose or worn parts.
All of the above.
A steering stabilizer is not a cure, or even a temporary fix for swerving. If it was, it would be so stiff that it would keep you from steering correctly.
You can’t just tug on most of these items on a truck to see if they’re older or loose. You have to do other things, such as the steering test that was previously pointed out.
Keep the full weight of the vehicle on the ground while the helper is turning the steering wheel back-and-forth.
When you use the steering system to push against the weight of the vehicle, you can see anything that is loose or broken.
Last, but certainly not least, old tires are very bad. Could be 100% of your wandering/swerving issue. Or it might not be.
You said the pressures are equal, but what are they? Too much, or too little is almost as bad as too old.
What are the date codes on the tires? Tires can age out long before they wear out sometimes.
Especially on Broncos that aren’t driven much!
73azbronco
And check U-bolts on rear axle.
yeah, fun fact, had a spring shop check my e450 springs. Felt odd thunk after their work, their work was to losen axle to spring bolt, forgot to tighten them...
And doing that is easy. Perform the test that SteveL described previously and you will see if the gearbox is moving on the frame.
It doesn’t happen very often with modest use and small tires, but a cracked frame is not an uncommon thing on Broncos.
