Green-red wire from the old voltage regulator.
Old post, but i figured someone may some day benefit. I think this would provide reliable 12V in start and run. using a relay instead of a diode. Advantage being that you can get more amperage than a diode setup would allow(restricted by the factory wire size).
This uses the green w/red stripe wire that comes off of the voltage regulator as the trigger. In start, the green/red does not get any voltage, and the coil is in the open state with pin 87 getting power from pin 87a which is connected to the I terminal of the starter solenoid. When the key is released and changed to a run state, the green/red gets 12V, closing the relay and powering 87 from pin 30 connected to B+.
After reading too many threads, I was under the impression that red/green was unreliable for start.
Again, I was under the impression that the I was internally switched by the starter solenoid and it was open when the starter was disengaged.
You appear to be replying to my statement about the ig.sw. "I" terminal, but you're replying about the starter relay "I" terminal. They're different, and do different things. Don't confuse them just because they have the same label.Again, I was under the impression that the I was internally switched by the starter solenoid....
