Test Running Engine
BoureeOne
Madisonville, La
My engine and drivetrain are complete (frame only, no body). I want to test run my engine. How do you test run an engine in a frame? I don't want my serp belt installed, cause P/S and A/C are not hooked up. Can I find the belt for the PS and AC delete? I know there has to be some good tricks for doing this.
Rustytruck
Wild horses has a starter bracket 9235 to mount the starter if you dont want to mount a bellhousing.
BoureeOne
BoureeOne
Madisonville, La
My engine, trans, transfer case, drive shafts, everything for the complete drivetrain is in the frame.
BUCKWILD
Butte county
just start it. no coolant dont let it run mor than 15-30 seconds it will be fine. you need more time than that. if it has coolant and a radiator it can run a bit longer
And with open headers you probably don't necessarily want to run it longer than that anyway!
Or at least the neighbors and dogs don't.:eek:
broncnaz
AC not hooked up no problem the compressor will not turn unless you power up the clutch. PS is another thing. But you could probably just loop the pressure line into the return line and be fine with just a little oil in the system, wouldn't take much just to hook up the steering box either. Of course if this is a new build ie rebuilt engine Id wait till you can get a radiator hooked up. new engines tend to run pretty hot and no radiator equals bad idea. So waiting would be better no matter how temped you are to run it. Especially if your trying to tune that tri power setup.
Is this going to be a quick fire up, or a long run to break in the cam?
A quick fire up is no big deal No water or anything else needed. Not much different then running a lawnmower engine. The block and heads being cold can take a minutes worth of idling and not overheat.
Now a long run, cam break in. That will take cooling. A garden hose will provide enough cooling to idle, that is how boats get run out of the water. Fake-a-lake just puts a garden hose in place of lake water. But boat engines still have a thermostat and a way to get up to temp. Typically some complex cooling loop/bypass so the engine can warm up but still keep water flowing through the exhaust manifolds.
This should wait until you have more of the vehicle built, so you can have a proper cooling system that will let the engine really come up to operating temperature.
BoureeOne
BoureeOne
Madisonville, La
Thanks for the advice guys. Here are my plans. I am going to get my radiator set up in a temporary situation. I can set up some air blowers to act as a fan. I am going to source a shorter serp belt so I can bypass the a/c and p/s. I want to know this thing is going to run correctly before the body gets put back on. So this means I want to do a normal engine break in. And yes, I am very anxious to hear this thing run. I am now over 5years into this build.
Thanks again.
Rustytruck
Its beautiful and expensive and worth every penny you have invested to start it properly. You probably have enough old parts to set up a start board with all the switches and gauges you will need to properly monitor and start the engine. If I were you that's what I would do. I would want it running perfectly before I plop a body on it. You are probably going to spend some time getting those 3 carbs in sync. I would build a wood frame to mount the radiator you plan to run and bolt it to the frame rails. Run to the wrecking yard to get some long hoses and build a frame mounted run in stand. Whats another week after 5 years. Borrow someones plastic boat tank for a fuel tank. Probably could just mount and use the Bronco fuel tank you have to mount it all and run lines anyway but you may not want fuel sitting in your system until the rig is complete.
Nothing like running an engine and tuning it when you have no obstructions around you. You do have to be extra careful around unguarded moving and extremely hot parts though. Burnt skin and dried blood are hard to remove.
blubuckaroo
Grease Monkey
Ridgefield WA
Isn't there a way to connect a garden hose to it and run it without belts?
Sure you'd have to remove the thermostat because of the city water pressure, but other than that, I can't see how that wouldn't work.
It can be done, but you will never get the engine warmed up.
tirewater
San Francisco Bay Area
Thanks again.
Do you have a roller cam or a flat tappet one? Flat tappet cam break in is suggested 20 minutes of 2k+ rpm. Even with a muffler it'll be loud.
Break in will depend on how well your engine will actually run. Timing will likely be off as well as the carburetors being out of sync.
Do you have an automatic transmission? If so, it'll need to be filled and the cooling lines connected (if applicable).
Heh, my first break in run resulted in the lower water pump radiator house popping off and creating a mess. The second attempt had the transmission dump fluid from the input shaft. I hope your first attempts are better than mine. :)
