anybody know a trick on how to test the temp gauge in the cluster? i have a gauge not working, already replaced the sending unit. wanna test it before i pull the cluster to replace it.
easy test before you install the sending unit. wrap a wire around the body of the unit to ground it. boil some water and drop the grounded sending into the boiling water. the gauge should read whatever temperature water boils at your altidude. 212 on the coasts and maybe as low as 180 in the mountians.
+1 ......if you're not getting a reading, check your coolant level or for an air pocket in your cooling system. If that's ok, make sure you have power and a good signal at the gauge. I've seen people tap sensor wires for aftermarket equipment grounds... A cheap $10 meter will help you check continuity and voltage.
