crutch
- Jul 3, 2015
- 249
I have a new TBP temp sender with the original instrument cluster on a '72 bronco and can't get any temperature reading on the gauge.
I've reviewed a few different threads on how to test the temperature sender and gauge and wondering if anyone had any thoughts on next steps. Here is what I've done so far.
I grounded the temp sender wire and the gage pegged all the way hot.
I took the temp sender and tested it in a stove with water and got the following readings:
145 deg = 83 ohm
175 deg = 52 ohm
205 deg = 33 ohm
I am not getting any reading on the gauge when I connect the sending wire to the temp sender ever when driving for 20 minutes +.
Do these resistance readings look ok? I was thinking I'd pick up a few different resistors in this range and connect to the sender wire and see if I get a reading on the gauge. Any other ideas or something I'm missing?
Thanks as always!
145 deg = 83 ohm
175 deg = 52 ohm
205 deg = 33 ohm
Thanks as always!
