testing temp gauge?
73stallion
Eugene, OR
anybody know a trick on how to test the temp gauge in the cluster? i have a gauge not working, already replaced the sending unit. wanna test it before i pull the cluster to replace it.
4x4man514
Augusta,Georgia
if you ground out the sender wire the gauge should go to the highest temp. if it does nothing the gauge is bad or there is an issue with the wiring.
oleguy74
calif city ca
temp is same as fuel gauge.so is oil pres. 73ohms about 120*,21 ohms is 195*,10 ohms is 230*.gauge res is 10-14 ohms with all wires removed.
00gyrhed
easy test before you install the sending unit. wrap a wire around the body of the unit to ground it. boil some water and drop the grounded sending into the boiling water. the gauge should read whatever temperature water boils at your altidude. 212 on the coasts and maybe as low as 180 in the mountians.
brianstrange
+1 ......if you're not getting a reading, check your coolant level or for an air pocket in your cooling system. If that's ok, make sure you have power and a good signal at the gauge. I've seen people tap sensor wires for aftermarket equipment grounds... A cheap $10 meter will help you check continuity and voltage.
73stallion
73stallion
Eugene, OR
sounds like it'd be easy enough to hook the wire to the fuel gauge and test it that way, i'll do that tomorrow. thanks oleguy
