Last 2 weekends have been nothing but sanding, priming, followed by more sanding and more priming, followed by yet more sanding and priming.
But at the end of it, we got both doors, window frames, hood, fenders, and tailgate into Guide coat where they will stay till we finish the rest of the tub.
Having to do it in batches as I don't have enough room in the paint booth to do it all at once.
When we built the temporary paint booth in part of the garage I thought it was HUGE...LOL... now I feel like it can't fit shit. Same with the garage, technically its a 6 car, but can barely fit one right now. (for sure a first world problem)
Next up is priming the rest of the tub and putting the front end back together so we can bondo up the sides of the grill to get it to match the fender.
Been awhile since I posted an update. Life has been busy and have only had time to work on the bronco a few hours at a time on weekends, but we are starting to see progress again.
As of now the bronco is in full guide coat, with the exception of the grill which needs a bit more work.
Everything is fitting great at this point...however every time we take her apart she seems to want to go back together slightly different lol.
We've decided that we are going to move forward with wiring and getting the bronco running again before doing final sand or paint.
We've been 3 steps back for every 1 step forward on this rebuild, so even if it makes the final painting a bit more effort, not having to worry about dinging up the paint while trying to get her wired and running will be worth it.
Also got the dash fitting nicely and am starting to figure out what I want it to look like now.
Not a lot of progress, but progress just the same. Super excited to hear her running again.
However, it turns out the painter/bodyman I hired who had the bronco for 6 months turned out to be a complete douchebag.
He raped the bronco.
He has zero desire to fix or make right and said he'll just declare bankruptcy if I take him to court.
I agree.. I like that dash layout. Where did you source the billet bezels for the rocker switches?
Double check the clearance behind the pioneer stereo. If its a double din type you may need to lower it. It took me a while to find one that would fit behind the dash. Its tight back there. Looking good. Love to see the progress.
Keep plugging away, progress is good...driving it will be the big payoff!
Today we framed up our temporary paint booth and started hanging the plastic.
Thats what I've been told. Heard lots of horror stories. I went with a pioneer that allows for the screen and receiver to be mounted separately. So only the screen mounts in the dash...about an inch thick. then connects with cable to the receiver which if all goes to plan will be in the console or under the passenger seat.
Great idea. I have yet to see that set up. Looking forward to seeing it installed.![]()
