I did a little more research and here's what I found, directly from the Eaton site:
http://www.eaton.eu/ecm/idcplg?IdcS...veAs=0&Rendition=Primary&dDocName=PCT_1087652
"High quality mineral or synthetic gear lubes are required for use in Detroit Truetrac differentials. Regardless of the lube type, always use a GL5 rated lube with the least amount of friction modifier. Mineral lubes lacking friction modifiers (limited-slip additives) were historically recommended for all Truetrac applications because friction modifiers can slightly reduce the bias ratio (limited-slip aggressiveness) of Truetrac differentials. However, to address the continually increasing power outputs of modern powertrains, many vehicle manufacturers have switched to synthetic lubricants as a counter measure for increased axle temperatures and prolonged service intervals. In general, consult the vehicle owner's manual for the manufacturer's recommendations for lubrication type, weight and fill volume. This will ensure lube compatibility with the seal materials and bearings used in the axle. Eaton Performance technical support is available for any concerns in lube selection."
I must have read an earlier version of their owner's manual that said they recommend mineral oil only for the Truetrac. And the Lucas 75w-90 gear oil exceeds GL-5 spec.
-Chris
