Thoughts on Fair Value for Ebay EB?
YelloTx73
Katy/Galveston, TX
Looks really nice. I love the look of a lifted uncut eb. I would try and request more photos, that is if you can't go visit it in person. You might even be able to get one of the California guys to check out for you if you can't. It looks really clean, but photos can be deceiving. Good luck
GB
Boulder, CO
Relisted on EBay
For whatever it is worth, the same dealer had it listed on ebay a while ago. Maybe 1 month ago.
Don't think they got the reserve.
supermottl
Indian Harbour Bch,
It looks real clean. Dash pad looks painted???
I noticed it didn't have a few important things like power brakes, power steering, drop track-bar bracket (or riser on the axle) and no rollbar. All these things can be added, but just add a few thousand more $$ to it... Ouch, drum brakes all around too %) . oh yeah, lift blocks in the back too :-X
but I'm just pointing out the bad things to give you some bargaining chips.. it's a nice solid platform from the pics
Daddy4zack
El Dorado Hills
That sure is nice!! I would call or e-mail them and ask them what thier reserve is set at. That will help you decide if you are in the same $$.. Yes there are a few things that could be done to it. But for a Daily driver its nice.. This will not be a trail rig! so it all depends on what you are after. Someone spent a lot of time and money on it.. And rember for some reason Broncos are more exspensive here in California..
74bronc
i would raise an eyebrow with the seller since he called the rear end a "10 bolt". I would definitely get more info on it and the seller before bidding. Although I would never buy a vehicle off the internet sight unseen either, but that is just me.
sstlaure
Bronco Slacker
Looks clean, it says 10-bolt rear end, but it's a Ford 9" (scan way down through the pics), which isn't a bad thing. With them being off on that, I'd question any of the other specs they have listed. Maybe someone in that area would take a look at it for you.
daddyg
Bronco Parts Collector
Toney,AL
I would be surprized if the reserve is less than 10k. Very nice looking Bronco. I did notice the passengers side door is a little out of adjustment, but heck most are. I would love to have that for a daily driver.
stevew
Elliston Montana
It's being sold by a car lot .. so figure they don't really know anything about it other that what the guy that traded it in told them or maybe it was wholesaled from another lot that took it as a trade in . Either way , highly doubtful ANYONE there knows what it really is . Go see it in person & KNOW what you're looking at .
LA Kevin
LA Kevin
Pasadena, CA
PS
Sebastopol, CA
Being in California, I'd suggest you stay away from '75-'77 due to the smog laws. Any of these years will require a smog check every two years, the rolling 30 year exemption has been eliminated. I know '76's & '77's have all the goodies, but disc brakes and fuel doors can be retrofitted easier than dealing with a smog check on a 40 year old vehicle (assuming you plan on keeping it for ten years...).
Has LSUPete sold his latest creation yet?
WichitaBronco
OK - Here's an uneducated question . .
supermottl pointed out the lift blocks. I know what they are, and I think I know the answer, but what is wrong with lift blocks and what are the alternatives? Leaf springs, suspension, etc. Specifically for a daily driver.
My dad always told me there was no such thing as a stupid question, just stupid people.
302fix
Looks like a nice Bronco.
Removing the blocks is an easy upgrade. Get the correct size leaf springs or add a leaf for less than $200. Just a better/safer ride.
Two things I noticed:
1 - Check out the C bushings on the radius arms. It may be just the picture, but it just doesn't look like the correct offset bushings (again probably just the picture because otherwise I doubt they could draw the bolt down).
2 - Will need to upgrade to disc brakes.
Real nice though. Probably worth going to check it out. Bring a magnet.
Oh yea... I also noticed that the floor shifter looks like it may get in your way. Something I'd want to sit in and check out. If it's your daily driver that could become quite a nuisance.
LA Kevin
LA Kevin
Pasadena, CA
Gave him a call, didn't recall any tears or issues on the dash or anything else materially wrong with it. Reserve's at $12.5K, down from the $13-14K they were looking for last time they ran it on ebay. As already noted, no disc, no power steering, etc. May be a little more than I'm looking to spend prior to adding all those key items. May be actually leaning toward the other one in SD.
Anyone in SD near SDSU that could take a quick peak for me before I sit on the 101/405 for 4 hrs each way? Many thanks! Hope to join the ownership ranks soon.
dan12580
personally i wouldnt pay anywhere near that for one with no power/disc brakes or power steering. i paid 7k$ :) for my daily driver with power steering/brakes, disc, c4, and a whole lot of other things but without the pretty paint job. :( look at autotrader.com, thats where i found mine.
