Well I finally got it running pretty good, now I am stating on the drive train. Two wheel drive is not too bad, maybe a little transmission roar(3 speed). When locked in high or low there is quite a bit more roaring. Its not too bad at lower speeds but if you drop the three speed in neutral and coast at higher speeds the worse it gets. Does this narrow it down any? Would this indicate the transfer case as the culprit?
