abrush
Well luck has not been on my side lately and once again today I ran into a downfall. I had to remove the water pump on my 1970 Bronco with a 289 to replace it and noticed that the water pump bolts appeared smooth or stripped on the threads when I removed the bolts. However they were very tight and it took a lot of effort to get them to back out. When it came time to put the water pump back on a couple of the holes were indeed stripped as I can't get the bolts to tighten up again. I tried new bolts and even longer ones to no availability. Is there a fix for this or am I screwed again and have to remove the timing cover and replace with a new one???? Please advise.
