Timing problems on new rebuild
The tools in the video can be had from IPA, or Innovative Products of America who have a boatload of very clever tools for various pursuits.
savage
Bronco Nut
Renton
And again, you did say you verified the old firing order? I guess I just find that strange for a roller cam, but nothing says the manufacturer can't do it that way. Just doesn't make sense for a modern cam with modern profiles, to run the old (less desirable) firing order.
I found that odd ,but here is comp cams write up on that.
Well there 'ya go. Thanks for that technical note page. Now if I can just remember 31 and 35 when reading someone's part number in the future!
Good stuff to know.
J
jasonv
Thanks guys, looks like you went and found all the info on the cam I have at home.
I've seen that video. should get a piston stop and do it right? All I have on the balancer is a scratch mark. The original marks are gone. It's an aftermarket balancer, the original rotted and this doesn't have stamped marks.
So back to the timing. In his video he has the distributor set like it should be? That's 180 from where I have it set. So basically I have created my own issues. The engine is probably TDC but I have the distributor set backwards. No surprise there, user error!!
But as somebody pointed out as long as the plugs line up and are ordered correctly it should work fine backwards? I have the distributor pointing at 6:00-7:00-ish compared to his 1:00 but also have plug #1 at the same place.
"Shut up brain you have no idea what you are talking about, just do it like everyone else"
savage
Bronco Nut
Renton
In the video he says he's off a little, he points to were it should be pointing at, between 12 o'clock and 1 o'clock . It sounds like your 180 degrees off. see on this pic where number 1 is.
B RON CO
Statesville, NC
Hi, can you put your cap on and show a picture of where #1 plug wire is on your cap? Point to it and make it easy to see. Then we can think about what to do next. There enough guys here to talk you through it once we see where you are at. Good luck
J
jasonv
Here the picture from the bronco shop manual.
I'll get so photos of me trying to set it up this way later when my son gets home.
B RON CO
Statesville, NC
Hi, something is weird with the manual you are using, but it should work. You should next show the cap off, where the rotor is when you are at top TDC, compression stroke. I would slowly turn the engine over until the rotor is pointing at #1 on the cap, 6 o'clock, and see if the pointer and mark on the balancer is close. That is a starting point. I assume the distributor is a few teeth of, and the balancer is marked properly. Good luck
savage
Bronco Nut
Renton
That's the same shop manual I have, and all the fords I've ever owned, never had number one in that location. So I have all ways done it with number 1 at 1 o'clock location, so It will be interesting to see if that way works for you. I don't see why not as long as your on compression stroke and you make that location as your number 1 plug.
Correct. As you and others have pointed out, the parts don't care how they're aligned, as long as they're all aligned consistently and together.
You can put the rotor anywhere you want, as long as at TDC on #1 the rotor is pointed at the #1 plug wire terminal. Wherever that may be. And the rest follow suit in order.
And even if you were "a tooth off" on the distributor, if the body of the distributor can be turned far enough, you can still time it. The trouble for that comes when you run into something that interferes with the movement. Which is why sometimes a tooth off means you have to redo it.
The picture in the book does not look like a Windsor based V8 to me. I know they say it's "typical" in the text, so it could be any engine available those years the book covers. But if that's a 289/302, it's a very early one.
That aside, keeping the #1 over in that position shown in savage's diagram will help others work on it if needed.
As long as the firing order of the wires is oriented properly from wherever you have your #1 wire, the rest should fall into place.
This is more work, but since you've already had the valve cover off once at least during this process, doing it again might put this all to bed once and for all.
Pull the cover, crank the engine with your finger over the hole again, and watch the valves go through their sequence and wait for the single hard blow against the finger after the intake valve closes and all remain closed.
Tell him to bump the starter, instead of letting it crank fully. A tap here and there should let you easily stop when you see the right place.
Remember, the crank turns twice for every one turn of the cam. So 180 out on the cam is actually 360 out on the crank markings.
You should see this sequence (sorry if this is just repeating what you already know) during cranking/spinning.
(piston passes TDC on the exhaust stroke)
1. Intake valve opens
(piston is moving towards BDC (bottom dead center)
2. Intake valve closes
(piston coming back up towards TDC of the combustion stroke)
(both valves closed and you feel the blow)
(timing marks coming up to 0° or TDC of the combustion stroke)
3. Combustion takes place (ignition timing)
(piston goes down the bore on the combustion stroke)
(piston starts to come back up on the exhaust stroke)
4. Exhaust valve opens.
(piston heads up towards the top)
(piston reaches the top)
5. Exhaust valve closes.
(piston back on the way down)
6. Starts over again with the intake opening again and then both valves are closed and you feel blow.
It's all just suck, squeeze, bang, blow for your 4-stroke engine.;D
Of course, it's really a variation on that theme as they gradually open and close and have periods of overlap where both might be open, or one is open when the piston passes it's maximum top or bottom position. But that's in in a nutshell.
So with the valve cover off and the engine slowly coming around to the position you want, watch for both valves on that #1 cylinder to be closed AFTER THE INTAKE CLOSES and wait for the blow. When that happens, just watch for the timing marks (assuming they're there) then do your rotor alignment with the cap and wires. If that doesn't get you near enough to start, you may have other issues.%)
Good luck.
J
jasonv
Ok, spent some time today and confirmed that my timing mark is correct and we are on TDC of the compression stroke. I stabbed the dizzy and was able to get it to some side of the other. Marked the location for #1 wire and lined them up. Ok so not in that picture but I did live up the fit with the rotor.
So anything else before in try to fire?
B RON CO
Statesville, NC
Hi, I see a black mark on the distributor body. Is that #1 on the cap? As you have seen in the newer firing order diagram, the #1 post is more at 1:00. It seems you are set up at 12:00. All things being equal, you are just approaching #1 and a the spark is just getting ready to fire. Do you have full battery voltage to the coil? Your electronic ignition probably takes 12 volts ( no resistor ). I would be ready to give it a go. When it does fire up you need to keep the RPMs up, and watch the water level (have some water ready to add) and don't let it over heat. Good luck
https://www.google.com/imgres?imgur...jUAhUN9WMKHQCaAF0QMwiaASg5MDk&iact=mrc&uact=8
Look at this picture. This is where the distributer should be when installed properly. To get there take off the passengers side valve cover. Then put your finger over the spark plug hole. When you feel pressure stop and look at the rocker arms over cylinder 1. If your near top dead center both the exhaust and intake rockers will be up. If either valve is down pushing the valve open then your 180 degrees off. Once you get the cylinder 1 under pressure with both valve rockers up then put the engine to TDC. Now look at the picture i sent. Put in the distributer so it lines up with the picture i sent. Mark the distributer body next to the cap at no.1 wire with a sharpie. Remove the cap and transfer that mark on to the top edge of the distributor body where you can see it. Now install the distributer and line up the distributer body with the picture. As the distributer goes down the hole the gear on the bottom ingages the cam gear and twists the rotor. You have to off set the start of the gear so once its down it lines up the rotor with the mark on the distributor body. Some times as the gears line up the distributor gets hung up on the oil pump drive shaft and wont go all the way down. In that case put down ward pressure on the distributer body and move the crankshaft. As the crank turns the camshaft and distributer gear move and it lines up with the oil pump drive shaft and now the distributor will go all the way down. Now move the crankshaft back to top dead center and make sure everything lines up properly. Right now you are a tooth off on the distributer gear or 180 off. 180 off you usually backfire through the carb. A tooth off usually doesnt fire properly.
In your picture if the mark on the distributer body is #1plug wire and if you are on top dead center compression stroke, the wires on your cap are one hole off and all the spark plug wires need to be moved in the cap one hole clockwise.
J
jasonv
Ok. More tinkering. Engine at TDC. new mark on the dizzy and firing order confirmed again 1-5-4-2-6-3-7-8
Burns fuel, won't run
Jason
Skiddy
did whoever built the engine line up the timing marks on the crank/cam?
J
jasonv
I would assume so. The builder has been doing it for almost 30 years and has an excellent reputation. A mistake by him is low on the probability scale. I guess I need to give him a call Monday.
We pulled the valve cover today and double checked the timing several times. Timing mark, valves and piston all look to jibe.
Joe473
What happens when you move dizzy while cranking? Is it flooded? Wait and then hold open choke and give it some throttle. Are you getting good blue spark?
I noticed the roller tip adjustable rockers in one of your pics with heads that appear to be late model pedastal heads. Did builder check pushrod length and check lash during assembly or did you do the valvetrain?
Sent from my SM-G900V using Tapatalk
J
jasonv
I did, new distributor!! Go MSD. scary part is the Summit distributor is the same body. Fired up on the first crank. Whipped out my dads 50 year old timing light and set the timing, runs great!
Jason
