...Mine is at least 10 years old, worth replacing I figure. Any thoughts?
It's part of every tune-up, so after ten years (but do you know how long it's been run?) it certainly should have been replaced at least once.
You don't need to do that each and every tune-up, but after a few cleanings they say not to rely just on how it looks or rattles. At some point you just need to put a new one in.
Again though, depending on mileage/hours more than years I would think. If it's 10 years old, but only has 1000 miles on it, likely it's good. As long as it was the correct one to begin with.
Since they're cheap, it wouldn't be a bad thing to buy a new one for your specific application and keep the old one as a spare for the next time.
ive never checked points but it seems pretty straight forward so ill do that.
Well, it's not. Ok, so it is very straightforward once you've messed with them a bit, but I'd have to say there is a learning curve for the first-timer.
The typical tools needed would be:
1. Your eyes first of course, but that's just the beginning.
2. A "points file" or fine sandpaper folded over for cleaning used points. The mating surfaces of the two halves need to be smooth and clean. If they're pitted or messed up enough, they simply need to be replaced.
3. A gapping tool of some kind. Usually feeler gauges, but there are multiple types.
4. A dwell-meter is as important as a timing light. Yes, you can get it pretty close by simply adjusting the gap, but the dwell meter is basically your double-check for your gapping skills. Doesn't take much of an error in gappage to make a tidy error in dwell. Ultimately, dwell is the rating of points adjustment.
5. The timing light of course. Not points specific, but each time you manipulate the points in a distributor, you actually change the timing. Could be just a little, but can be a lot.
...vacuum advance is hooked up to the carb. stock autolite carb. it connects on the left side.
I think that's the correct fitting (the "ported" or "timed" vacuum fitting), but someone else can confirm.
The hose does look a little aged though, as do most of the bits and pieces on the engine. Might be time sooner rather than later to replace a lot of the old tired stuff. You can find yourself chasing tails when old parts are left in service.
My rotor doesn't have weights so im assuming no mechanical advance and just vacuum advance?
I don't know much about advance so that might be a stupid/obvious statement to some. How do I check for play in the dizzy shaft?
That's actually a good point to make. You might be thinking of the old GM distributors where the weights were conveniently mounted on top of everything else, right in plain sight.
The Ford distributor's weights are beneath the points plate, so you can't see them. But if you can turn the rotor by hand a few degrees smoothly and have it spring back all the way, with very little to no slop, you have mechanical advance weights in place.
For checking play, there are to dimensions in question usually. Aside from the movement you get from the advance mechanism(s) you can push and pull the shaft sideways to determine if the bushings/bearings are worn. There really should not be much (if any) perceptible play in the sideways direction.
Next you have up and down play. There is a specification for that, but I don't remember what it is. Someone can post up the info, but here again it's not a lot. If you have more than 1/8" up and down movement we should make sure that's normal. Been awhile since I wore out a distributor, and now my driver doesn't even have one!;D
Sorry I can't remember all the stuff, but that's why we're all a team here. Someone's always coming up behind to take the baton and run with it!
Good luck. Should be able to get it running like a top once you go down the list, read all the proper books on how to do this stuff (unless you've done some of this kind of thing on other types of engines already) and you'll get the basics down.
