Torque main caps before machine shop work
theshadow
Getting ready to send my block over to the machine shop, and I've read you should torque the main caps prior for proper bore shape.
But seems like new main bolts are a torque once kinda deal. Are these two points correct, and if so, should I just use the old main bolts and torque them down for the machine work?
Thanks!
Sent from my Pixel 3 using Tapatalk
theshadow
theshadow
Ok, after reading fine print the main bolts I will be using are not TTY, but the question still remains - is best practice to torque down main caps before sending off to the shop?
Seems like the shop that's doing any machine work is able to torque the caps themselves, if it's decided that this is needed for the work they're doing.
It does make sense to me, just like using torque plates when honing or boring a cylinder.
But if machining of the crank bore is part of what is being done, then I'm pretty sure there is no way to do any machining without having the caps torqued.
Whether it's done by you beforehand, or by the machinist to verify things, is worth a call to your chosen machinist.
nickgp
I’d leave that to the machine shop. I doubt any good machinist would trust someone’s else’s torque setting.
JWMcCrary
X1000, If I have to torque them myself to make sure the machine shop does it correctly then I'm in search of new machine shop. I just snug them down, no torque.
Timmy390
Conway, AR
The shop should wash the block before doing anything. They remove the mains caps when washing. It gets a rewash after work is done.
How my guys does it.....
Tim
Go ahead. Nothing special. Depends on what order the machine shop does the work. If they line bore first, it's all coming apart and going back together first. If nothing else the shop could also pull the caps as part of the block inspection before they do any work on it.
So I am going to say, not critical. IF you delivered the caps loose in a box that should work as well. Although I would install them in the block to minimize the chance they get lost. But you will probably be taking them a box with pistons and other stuff as well.
The main caps might have a slight distortion on the bore. Maybe this might matter on a full built to the absolute limit race engine. Typically as fancy as anyone gets is a deck plate for the bore and hone. The head bolts run right next to the cylinder walls and that will do WAY more distortion than torqueing the mains. And by way more, still not enough to matter for a normal rebuild. Generally good practice for a performance build.
So "need to be torqued before delivered to the machine shop", big fat -NO-.
Nothing wrong with it. But nothing gained by doing it.
theshadow
theshadow
Great feedback everyone - just what I was looking for.
Thanks much -
