After 15 years i finally have my project complete and ready for its first test ride. On the first ride out it has what i would call severe torque steer IE when you hit the gas it pulls to the left and when you let off it goes to the right. If you go at a consistent speed it goes straight down the road as it should. Hitting bumps in the road has no effect so i very much doubt it is a bump steer issue.
It has a 3.5" Wildhorses System 7 lift with the larger U bolts and Shock Jock rear mounts along with a torque tamer. Everything in the front end is new, tight, drop pitman, drop radius mount, adjustable draglink and radius rod, etc. everything is centered, no play etc. Tires are new 35x12.5x17 and 5.13 rear ratio in the axle. I tried measuring the rear tires and the diameter is within an 1/8 inch between the two and i also tried varying the tire pressure on each side with no change. Motor is pretty healthy but i haven't even put the coals to it yet.
I have not tried it with the torque tamer disconnected but can if need be. I did a search for torque steer in the bronco tech section and have read all of those posts for the past ~ 5 years.
I do have an older Detroit locker in the rear and from the reading i did it looks like that is likely the culprit. I am just looking for a few to confirm that replacing the Detroit with another type of locker/limited slip fixed their issue before i go out and buy a new locker/limited slip. Vehicle will be mostly used on the road so it doesn't need a locker in the rear, i only used the Detroit because i had it. Limited slip would be fine assuming it would correct the issue.
Any help confirming the replacement of the Detroit will solve the issue or another solution would be greatly appreciated.
Xltboy
Xltboy
