Torque Steer? Possible causes/solutions?
yewhi
yewhi
San Diego
Thanks Paul!
The PO (18 years ago) installed the entire 77 front end including the stock Y linkage. That was why I ordered the Y to T swap kit since that seemed correct given that I assumed the PO had replaced the 73 pitman arm with the 76/77 to use the Y linkage.
I'll install the wheel spacers and adjust the tie rod today. I'm taking the bronco on Monday to a shop in El Cajon to do the install since I have neither the equipment or skill to weld the bracket. They seemed to like the idea of using a trac bar riser rather than a drop bracket (I assume that means they'd have to do the tire rod over knuckle install like Whoaa did above) with the intention of using the stock pitman arm. I told them I'd drop off the parts, let them evaluate the issue, and if they choose to use the drop bracket/arm they have the parts.
Keeping my fingers crossed. They seemed pretty knowledgable so hopefully we'll get everything wrapped up. Bronco Daze are coming up quick and I'd love to get everything buttoned up to attend.
Thanks again!
Ok, sounds good. It does sound like you have a '77 pitman arm, so would necessarily order the same in the dropped version.
But still use the correct earlier model drop bracket. Risers fit all years, so you're good there.
A riser is stronger, but not necessarily the best bet for everyone. Does make for more work, and for more figurin' n factorin' when it comes to keeping the geometry correct sometimes too, but can work very well when done right.
I like that you gave them all the options and can let them play with the various parts and lay it out the best way.
Be VERY interested in how things end up.
yewhi
yewhi
San Diego
Well, it gets even more interesting..
I adjusted the tie rod as per your recommendation and it is a completely different truck! Adjusting the tie rod essentially cured 90% of the problem. Wandering and bump steer are completely gone. It still pulls to the right slightly on acceleration but it is all but unnoticeable. In fact, if I weren't looking for it I'd probably miss it.
The steering wheel is not completely straight after I made that adjustment so I'm going to still take it in and have them tweak the alignment a bit. As far as I can see there is no need go to the extra expense of the additional work. I had this up to 60-65 MPH with confidence and it was predictable and rock solid.
Honestly, I can't thank everyone enough and you in particular Paul! You guys are the greatest!
I owe you one (OK maybe 10).
Tim N.
Yeah, custom axles are available that way probably (http://www.wildhorses4x4.com/product/Extreme_Duty_Rear_Axle_Set_6675yr_Sm_Bearing_10in_Drum) ;), but at that point, since you need a center section with larger bearings and bores, you might as well be upgrading the whole thing to a stronger housing and big bearings too!
That's great news yewhi! Glad you got it more dialed.
The bit about the steering wheel being off is easily corrected by simply turning the one single adjuster on the draglink. In fact, that's precisely what it's there for.
Any steering setup like this is going to change the orientation of the steering wheel to the tires whenever there is a change in the ride height, or as in this case, a change in the angle of the draglink.
If you don't get the chance to take it to the alignment shop right away, simply drive the vehicle so it's rolling straight (with the steering wheel still crooked), stop there and loosen the upper two clamps again, twist the adjusting sleeve in whichever directly makes the steering wheel start to creep towards straight up and down, then tighten it all up. Done!
If you feel it's not completely straight after driving it a bit, do the same thing until it's right where you want it.
Have fun driving it around now.
Whoaa
I adjusted the tie rod as per your recommendation and it is a completely different truck! Adjusting the tie rod essentially cured 90% of the problem. .
^.....sweet!
So nice to have knowledgable Bronco folks providing tips and advice. Paul & others, are generous w/ their time.
Now you need to drive the wheels off of this machine! :)
yewhi
yewhi
San Diego
^.....sweet!
Agreed! On all counts. I adjusted the drag link this morning and centered the wheel. It's driving well enough that I cancelled my shop appointment. I'm going to hold on to the pitman arm and drop bracket and drive it for a while. After a month or so I'll re-evaluate.
I could not be happier!
TCN
bronconut73
TCN
We saw the "before" photos.
Did you post any "after" photos?
yewhi
yewhi
San Diego
Well, I only have one. But it'll give you a good idea of how the stance has changed.
Before...
After...
Much more aggressive. Had to remove the rack to get it in the garage. Personally, I love it!
TCN
That's a real beaut yewhi!
And I almost hate to suggest it, but I bet a set of white flares on the front would look great. Add a matching green stripe, or just a pinstripe really, to the outermost edge of the flares to really set things off!
But don't listen to me when it comes to paint. I've been debating the right color change for mine for 38 years now!
yewhi
yewhi
San Diego
LOL! Thanks Paul!
Unfortunately, I believe I'm done for a while. I have to wait until my wife either divorces me or forgets how much money I just spent before I can do anything else to the bronco. The former is much,much more likely. :)
Having said that a cowl repair is the next order of business. There's way too much bondo in this truck to ever justify putting much into paint. Plan is to fix it so my feet don't get wet when it rains and drive the wheels off it.
Thanks again! Drove it to work today. Rides better than I could've hoped just a couple days ago.
TCN
71BroncoSport
I found this thread because I'm trying to figure out if my 71 can feel safer when driving.
It just seems that it could shoot off the road if I turn too fast or hit a road groove. It doesn't go in any direction when accelerating, but it does pull somewhat to the side when braking. It used to do it a lot more before I had the brakes rebuilt.
I'm afraid to try an emergency lane change.
Like the OP, I also have a 2/5" suspension lift, 1" body lift and 33"x12.5" tires, but I have 28psi all around.
The Previous owner did the 2.5" lift. I can see my drag link grease fitting is at a 45 degree angle and I think I have the trac bar drop bracket, although it's not welded.
I originally bought a drop pitman arm, but it seemed the steering shock was at such an angle compared to the bracket, so I put the stock pitman arm back on. And I think that's correct, guessing by the parallel appearance of the arms.
I definitely have play in the steering wheel, which is what I was initially searching for, but thought my setup and the OP's setup was so similar, I thought I'd post here.
I also read that the pitman should be on slightly towards the driver wheel when centered. I definitely didn't do that. Is that something to be worried about?
Can the same experts tell anything wrong by looking at my pic??
Thanks.
Hey BroncoSport. Here are a couple of observations from your description and pic. (thanks for the pic by the way!)
It can still very easily be partially due to brakes. By the looks of it, still drums all the way around? If so, you're going to need to be come intimately familiar with the adjusting procedure. As you may have read around here already, the automatic adjusters do not always automatically adjust.
And on a lifted short wheelbase rig like ours, all four corners have to be adjusted very, VERY(!) closely to the one on the opposite side. Front and back don't have to be exactly like each other (although it certainly helps in overall feel) but side to side adjustments need to be very close, if not exact.
Just out of curiosity, how does it handle overall? Feeling wishy washy when maneuvering? Might be weak shocks?
You also might be dealing with wheel backspace issues with your larger tires. But we'll get to that later.
I doubt this is the root cause of any of your issues, but I would still experiment with tire pressures anyway. And because our rigs are not 50/50 balanced, nor are they typically loaded equally, and it's now modified from stock anyway, you might as well start fiddling around with pressures.
Let us know exactly what tires, what condition, and what max-press ratings are on the side. But don't hesitate to go as low as 25 in the rear and as high as max press in the front. While I usually find that about 30 works best there, I've run them in a very wide range.
Yes, trackbar drop. And yes, it should be welded. But not yet...
Your grease fitting angle is correct because this looks like stock factory linkage. It's only when that gets changed to the fully adjustable type that we need to worry about that angle.
Well, maybe not. Under most situations, a '71 with a drop bracket on the trackbar MUST use a dropped pitman arm in conjunction. Forget the angle of the stabilizer shock. It's by far the least important aspect of your steering geometry, and should never be favored over something more important.
For the angle, you're correct that it does look pretty good for now. But imagine a straight line through the pivot points and see if the two bars are still parallel. For us here, you'd have to remove the steering stabilizer and shoot another image so we can see the two better.
And if you don't mind, that would be great. Or at the very lease, post up an image taken from slightly farther to the driver's side so we can see the upper draglink mount more clearly.
That's fine. It's a good way of getting more attention to your plight while not getting off-topic for the original poster. Works for me!
You're going to have to do the big test that we talk about over and over again. It's something that should be performed any time there is some funky motion going on with the steering. It'll highlight any looseness in any part of the system that ends up at the steering wheel. More later...
Maybe. Maybe not...
Original manual steering gears, and possibly some early power setups were offset to one side when centered. But very quickly the power steering setups were re-oriented so that, when the steering box is on-center, the pitman arm is straight back down the frame.
Even your minimal lift can have an effect on this, which might even be exaggerated by the use of only the drop bracket without the pitman arm.
Personally, I would remove the upper draglink end from the arm, OR pitman arm from box, and start from scratch with centering the box. But I'd also do "The Test" (before or after) to see what's up with the excess play.
At the very least, you're going to need either/or/both the dropped pitman arm and the adjustable draglinks that are now available. In theory the pitman arm drop should take care of that, but the adjustable link helps fine-tune things.
OR... And here's the other "OR" of this setup. Since your drop bracket is not welded on at this time, you might consider removing it to see if it helps things. If it does, then you know we're on the right track. Whether the "best" way to run is with it again, or without it, will depend on how it feels on the road.
Is this your first older truck by any chance? How much play is present in the steering wheel? Usually these old trucks and utility vehicles have more play than a modern counterpart, which is why I asked.
If you don't find reference to the test, or how to verify the steering box is in it's on-center position when the wheels are pointed straight, let us know and we can describe it to you in detail.
Basically though, the test is where a helper turns the steering wheel back and forth while the tires are fully on the ground and you're watching underneath for any excess play.
I can virtually guarantee you'll see some rocking motion with the trackbar mount, and perhaps some rod ends, and bushings here and there, and maybe wheel bearings or ball-joints or yokes in the steering column-to-box input shaft, and etc, etc, etc.
It all adds up.
Good luck. Let us know if any of that will work for you.
Forgot to mention, that it's hard to tell in the pic, but the drop bracket looks like one of the Rancho brand products. Very well built, but does not drop the bar much. And it does look like the bar is pretty high in one of the holes. Just moved over to the passenger side a bit.
This is probably why the two bars look so parallel right now. But looking again, I think I can see that the upper draglink end is higher in relation to the upper trackbar eye, than are the two lower points.
It's not much, but even that's enough to mess up your steering. Especially when added to other things. It's one big team that has to play nice together.
71BroncoSport
Paul, thank you for taking the time.
It's my first old truck. My 69 Mustang has play in the steering, but it still feels stuck to the road, but I imagine that's because it's not lifted off the ground.
As for the overall handling, I haven't really "Tested" that yet. New shocks all around and the rear springs are new. When I got it, it was sagging the the rear. Based on measuring, I determined I needed 2.5" lift for the back.
The brakes were done by the shop that mounted my new Wrangler MTR's (33x12.5x15) on AR235185 wheels with 3.750 in. backspacing, -44.00mm offset. I am taking the truck up to them next Saturday because some of the wheel weights fell off over the winter. I figured I'd also get an alignment. Maybe the wheel weights, although not causing any shaking, could be adding to the problem?? I'll also mention about adjusting the brakes.
So I just took it out for a quick drive. At 40mph, I was doing some left and right turns and it handled much better than I remember the trip yesterday, but I was on good, flat roads without any patches or tire grooves. But I didn't take it any faster than 40.
Braking is another story. I still have the hard pull to the left (Into on coming traffic), although it was MUCH worse of a pull before they did the brake job.
Hopefully these are the angle of pics you requested. Maybe I don't have a drop tracking bar bracket now that I compare it to the ones online...
Also, I will mess with the PSI, but from what I read, the more PSI in the front, the more squirrelly it gets???
Thanks again in advance,
-Dave
bronconut73
You've got a drop bracket.
It is bolted over the factory bracket.
It really needs to be welded too Bud, but you already knew that....
