Torquing Leaf Spring U Bolts
Dyehard
This may be a dumb question, but.....I can't seem to figure it out. How do I torque my leaf spring u bolts if my deep well sockets are too shallow to tighten them down any further. I mean, I know I can tighten them with a wrench, but without using my torque wrench how will know that I have them right?
langester
MASTER OF MADNESS
If you have too much extra Ubolt above the nut you can always cut some of that length off with a grinder or a saw. If you do make sure to leave enough to work with later when and if you have to remove and reinstall the ubolts.
langester
MASTER OF MADNESS
There is never a dumb question. Some are easier to answer than others, but never a dumb question!
Have a good one!
Dyehard
Dyehard
Thanks Langester, I might give that a try. Merry Christmas!
If the u-bolt is too long for a deep well socket, get out the cut off wheel and trim them.
Cutting with a hacksaw can get old pretty quick, but if you have an angle grinder you can make quick work of all 8 tips with a quick swipe of a cutoff wheel.
Are these u-bolts new and used in conjunction with some other new components? Depending on what you're doing, leaving some extra thread is excellent advice!
If you're already as thick as you're ever going to be, such as with a new 11-leaf pack and a tapered shim, then you can cut them down to within just a few threads of the nut.
But it does make things easier. Torquing with a wrench is more than just a matter of getting them gutentight. Depending on the size of the bolts a minimum torque is going to be in the 60+ lb range. Up to about 120lbs for the big 5/8" size!
Have fun!
Dyehard
Dyehard
Paul, yes they are new and I just installed them with new 11 leaf, 2.5" lift springs. They are 9/16" and I did use 6 degree shims so they should be as long as they will ever need to be. Thank you all for the tips.
garberz
Bronco Influencer
Conejo Valley, Ca.
Torque them often over the next few months of driving. They tend to loosen as the leafs settle.
Mark
oldiron
Mark
Very good tip. They are not "set it and forget it" I was amazed at how much mine had settled after a few miles.
Greg
Steve83
...make sure to leave enough to work with later...
x2
Measure the well depth of your socket, and cut ~1/8" LESS than that above the BASE of the nut. If you cut too short, the next time you take them off, the u-bolt won't be unloaded when the nut lets loose, and it could rip out unexpectedly.
U-bolts should NOT be reused, so it doesn't matter about needing more length later - you should buy new longer U-bolts anyway.
PCDan
Park City
x2
/\ /\ Exactly this !! with a grinder cut off wheel. Will take you 10 minutes.
PaveBronco
Not sure if its common knowledge (which isn't that common these days) you must stabilize the torque, so keep going from nut to nut until no movement is noted when reaching the desired torque. Torque opposite nuts in this case, as there are only 4 and always a good idea to step up the torque, say 50, then 100...sort of thing. Same for wheels.
