Transfer case question
Bronk74
North Las Vegas
I’m planning on fabricating a bracket to mount onto the transfer case to attach to my floor Jack so I can remove/ install more easily. Any suggestions would be appreciated. I’m trying to figure out the Angel it sits at. If anyone know please comment thanks.
No help here, because I always did it the awkward way. Just trying to balance it on the top of the jack.
I think you’re going about it the correct way and trying to make a proper mount.
Interesting to see how it proceeds.
I know a lot of people have talked about doing the transfer case using special mounts or a dedicated transmission jack, but I don’t remember seeing any pictures here of special fixtures anyone made.
But I bet somebody’s come up with something.
Good luck!
bax
Old Member
Transfer case is a pretty easy install. Just press it up there and stick it. Easier than messing with a jack. However its you want the answer, Just set your cell phone to measure and put the edge of it on the inspection cover. It will give you the angle.
I once made a quick adaptor for a floor jack. Pure scrap. A "hand" to hold the front output and a "stick" to hold up the rear output. Wobbly is great as you can shake it into alignment. No measurments, just use stuff that is handy and "about right" and go for it.
mrdrnac
I made a cradle out of wood for mine and attached it to my trans jack, worked great but was probably overkill for what was needed. But sure made it easier when working alone.
Timmy390
Conway, AR
I did the same thing. Works GREAT
Tim
