Trouble installing pertronix
michael084
Santa Rosa Beach, Fl
I went to installl my pertronix (finally letting go of my old points) and there is this little nut that is right beside the points cam that is in the way. I have used pertronix on my FE390 before and it didn't have this part, am I going to have to go get a whole new distributor just to install the pertronix?
BlackHorse
If you are talking about that little spring loaded thingy then you have no problem the black deal in the Pertronix will not hit it. :)
M
michael084
No, it does hit it that is the problem. After I put on the magnetic pickup it rubbed. I guess I will just stick with points for now can't afford MSD. The points work fine for me, just wanted to get a little more power. I have been using them for about 11 years now anyway, I am pretty used to them.
YellowBronc
Bronco God
michael084 said:
Any of you guys have any idea what the little springy thing is? I am sure it has some purpose, so I can't just take it out.
The distributors I have laying around do not have the spring attachment but instead a smaller/shorter pin sticking up with a C-clip on it. What it appears to me is the swivel point for the upper plate. The upper plate is moved by the vacuum advance module. I don't have a fix for you unless you could hit some salvage yards and part out a distributor with the smaller piece. I could take some pics of mine to show you what some of mine look like?
Also, if you would be interested I could take one apart and see if you could swap it into yours????? I don't know, just throwing some ideas out there.
M
michael084
Okay, finally got the pertronix ignitor installed a couple of days ago. Had to replace the distributor, the new one didn't want to fit. So I put the old one back in to heat the engine up good while I used an emory cloth to take of a little of the circumference, then it slipped right in. I CANNOT SAY THIS LOUD ENOUGH, what a difference in the engine. I have been running Fords with points since I got my first truck, I had put an ignitor on my old 74 f100 , but on the bronco it made a huge difference in power. It made a huge difference in exhaust note too, my truck has never been loud until now, I never would have believed that it would do that. Used to if I revved the engine up high in neutral I would get an intermittent skipping, sounded like one cylinder missing every 5 or six seconds, that is gone too. If you are running points give em up, I held on a long time, I have had my Bronco for going on 8 years now I was always cool with the points, didn't figure it made much difference. ;D
