Trouble removing drum backing plate
crutch
I'm doing a drum to disc conversion on the front and I'm having a hell of a time removing the drum backing plates on both sides. I removed the six screws that attach to the spindle but it's not budging. Am I missing something? Any tips! A couple photos attached. Thanks!
crutch
crutch
Of course after posting this I got one to come off. It took quite a bit more of sledge hammer then I was expecting.
Steve83
The inboard side of the spindle flange (bottom of this pic) has a pilot that fits tightly in the steering knuckle:
...when it's CLEAN. When it's dirty &/or rusty, it's an interference fit, which is what you're discovering. There IS a slide-hammer adapter made specifically for pulling them, but it's generally too expensive for someone maintaining only 1 vehicle to justify buying.
So when you get them out, wire-brush the pilots AND bores thoroughly to remove all rust & dirt, and then apply anti-seize lube during assembly.
You should also thoroughly clean the rest of the spindle; to keep the bearing grease clean, and to prevent damage to the new (right?) inner seal.
