Recently removed my 302 and dropped in a rebuilt 351. Engine turns over fine with the starter, but barely starts and when it does it runs really rough for just a couple of seconds before dying. I also get the occasional backfire when trying to re-start.
I've double checked my valve lash and triple checked my firing order. I can't keep it running long enough to even mess with the timing or carb idle mixture.
When hooking up the spark plug wires, I put my finger over the #1 spark plug hole and had a neighbor crank the engine to feel for the compression stroke, so I'm pretty sure I'm not 180 degrees off with the distributor, but at this point I'll try about anything.
