josimps2
- Feb 8, 2005
- 198
I just took the weed eater out to a beater that has been sitting in a field at my parents house for about 4 or 5 years. I put in a new battery and an ignition switch. I pulled off the air cleaner and put some starter fluid inside the carb and tried to fire it up... nothing happened. I left it on and went and by passed the starter solenoid and sure enough it started. The problem is it fires up but it doesn't actually run. I shook the gas tank before I started and didn't hear anything at all so I filled it up with some new fuel and some fuel cleaner. Pressed the gas pedal and few times and still it won't run. Even with fuel in the carb it still seems like it isn't getting enough fuel. Any recommendations?
