Trouble Starting
josimps2
I just took the weed eater out to a beater that has been sitting in a field at my parents house for about 4 or 5 years. I put in a new battery and an ignition switch. I pulled off the air cleaner and put some starter fluid inside the carb and tried to fire it up... nothing happened. I left it on and went and by passed the starter solenoid and sure enough it started. The problem is it fires up but it doesn't actually run. I shook the gas tank before I started and didn't hear anything at all so I filled it up with some new fuel and some fuel cleaner. Pressed the gas pedal and few times and still it won't run. Even with fuel in the carb it still seems like it isn't getting enough fuel. Any recommendations?
So many areas to go wrong here. Anything from junk in the tank, split fuel line sucking air, dead fuel pump, clogged filter, clogged line, clogged carb, bad gas, rust, eletrical issues, the list goes on and on.
Providing that everything is fine (and after sitting 5 years don't count on it) and that it was parked there with nothing wrong with it (most cars are parked because something is wrong) it would take a while to reprime the fuel system. just cranking the engine might prime it, but a running engine will wake up a dry fuel pump much faster then a starter motor. You will probably cook the starter and kill the battery trying to prime it.
Go get a big can of flamable carb cleaner. Use that to start the engine. No little wimpy shots, use a lot of it. It will take a while to run through half a can. With some care (expect some backfires) you can run the engine off the stuff. takes almost a steady spray to run a fast idle. Cycle the button and feather the throttle to match that air/fuel ratio needed to keep it running. If it isn't running on it's own after half a can, start finding your problem.
Back when I was at a dealer we used the stuff to bring in cars with dead fuel pumps. 2 would go into the lot with a can. Open the hood, pull the air cleaner, one would sit on the engine hosing the intake while the other drove the car in. Shut the engine off by letting off the spray can.
josimps2
josimps2
Thanks, I just got back from picking up a steering column for this thing and it's too dark to give it a try right now. I'll try and fire it up sometime tomorrow and let you know if the carb cleaner trick worked. Hopefully, so.
josimps2
josimps2
Ok, tried the carb cleaner and still nothing. It appears as if it's not getting a spark to ignite the fuel. There is plenty of fuel and the engine is turning, but still nothing happens. I replaced the distributor cap thinking this may have been the issue... still nothing. Where should I go next? New coil, new spark plugs, or new distributor is what I am thinking. Any more recommendations?
Skiddy
I would start looking at all the wires sounds like some mice might have gotten to some of them.
Pull the cap, see if the distributer is turning. It may have been parked because the timing chain let loose.
josimps2
josimps2
Distributor is turning but it appears it has a light bit of oil at the base of it. Does this mean new distributor?
At this point I can't tell what you need. Figure out why you don't have spark and go from there. Since you don't appear to know the condition when it was parked, then add deterition of sitting for 5 years, it's anyones guess what you need. I would suggest checking the points first, if it is even a points distributer. I don't even know that much about what you are working on at this point.
josimps2
josimps2
New battery, new coil, new spark plugs, new fuel filter, new fuel pump later... Once I got all those put together the fuel pump was spitting out something the consistency of pond sludge so hopefully the last step in getting this thing mobile will be emptying out the fuel tank tomorrow and putting some clean gas inside. Thanks for the help so far.
canrel
Bakersfield Ca.
In your first post you said you bypassed the soloniod to get it to run.
1. Have you checked for voltage at the coil in the run position?
2. Does it crank over with the key? If not check the fuseable link at the starter soloniod.
If it cranks, check for voltage from the "I" terminal on the solonoid to the coil.( during cranking)
3. If all of this checks good, remove the coil wire from the distributer, crank it over while holding the free end close to a good ground and see if you get spark. NOTE: YOU MAY GET A GOOD ZAP FROM THIS WIRE, BE CAREFUL! You can put a sparkplug at the end of the wire and let the base set on the manifold to check for spark. Less likely to get zapped this way. If you have spark reconnect to dist cap.
You said it started before so I would think your points are ok. probably the fuseable link, ignition switch, or solonoid.
josimps2
josimps2
Ok, just dropped the fuel tank and emptied out the sludge inside. However, in the bottom of the tank I have a grease like substance that also coats the sending unit. Do I need to clean the tank and sending unit, and if so how? If not is it as easy and just putting the tank back on and putting new fuel in?
Skiddy
get a couple of gallons of carb cleaner and go to town. might want to replace the fuel line since it has all that goop in it as well
