krisbassett
- May 18, 2006
- 568
I'm looking to make a solid 500hp which isn't an easy task at 6000ft elevation.
What about 2 small turbo's?
Another option I was looking at with the turbos was going with a 393 instead of the 418? My reasoning for the smaller engine would be for less work clearancing the block and if I'm not mistaken I could use a taller piston giving me more piston skirt and a better wrist pin location. I'm still pretty sure I could get the power I'm looking for.
This is will also let me get my compression ratio where I need it where as the others didn't offer as wide of range of pistons.
http://www.coasthigh.com/Ford-393W-Reverse-Dome-30-0cc-Scat-Based-Kit-p/12349-sca-586-f393-1.htm
Also I'm seeing that Milodon offers a 4 bolt main retrofit kit for 2 bolt main blocks. It adds 2 extra 3/8" splayed bolts on the 3 middle journals. They claim it puts an end to crank walk. Would this be better than a main girdle?
