Updating my 11 year old build "Project Captain Crunch"
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
Been a while since I updated this thread so heres a photo dump:
My fav:
My dog:
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
Most recent project, new oil pan. The one I reused was leaking so I bought a new one from Duffs that didnt have a dipstick bung so I cut it up and transferred the bung from the old pan. I was also getting weird readings from the oil pressure gauge and decided to see what was going on in there haha:
Peeled back the cover on the pick up tube (reused from before the engine build, never looked in there and found this awesomeness)
So I checked the pump and it was ok (thank God) and ordered the new pan and a pickup tube
New pan: no bung
Little bit of cutting, rtv, and JB Weld... no more leaks (I cut the bolts down after this pic) :)
6 quarts of Royal Purple 10w30 and a new filter and now I'm getting some nice consistent pressure (engine was cold in the following pic)
dube
big lake Mn
being a welder for 37 years, i cant stand that J/B weld, not that it dont work but when it fails and someone wants to do it the right way its a pita to grind and cut out. but thats just me.
do what you gota do i guess.
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
I am going to start updating this thread. I've done a lot over the past 2 years starting with a 3 speed to ZF swap. Here are a few pictures from pulling the ZF from a 95 5.8 F250 at the local u pull.
Sent from my SM-G930V using Tapatalk
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
I went with an NP205, JBfab shifters, BC Broncos clutch line and crossmember. I resealed the 205 and added the JBfab shift detents while I was in there to grinding the shift rails for independent operation.
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
Once I got the tunnel modified to fit the ZF my current dash setup wouldn't work anymore so I ordered a BC Broncos dash blank. I transferred my Marshall gauges, F150 vents, wrapped it in zebra wood veneer and black leather vinyl
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
Here are some pictures of the mock up. I also swapped over to a GM steering column with a Lecarra wheel
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
Next up were tires, I refinished my mickey thompson wheels, got rid of the 33x12.50R15 dick cepeck FCIIs and went with 35x12.5R15 Falken Wildpeak Mud Terrains
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
I upgraded the stock style steering to BC Broncos Heim steering. Here is a picture mid install. I also had some coolant and oil leaks to fix. Replaced the rear main and oil pan while I was in there
