Hinmaton
- Oct 17, 2017
- 590
Over the years of having my FiTech occasionally I would have hot start problems, but they seem to be getting worse. In the past, I was always able to add a little fuel directly to the throttle body and it started right up, I had always assumed the Prime Shot function was fritzing out or something.
On the most recent trip it was happening every time the engine cut off- stall or otherwise (manual transmission). I was able to get it started a few times with the manual gas injection, but it began only running so long as the gas in the throttle body was present. I then noted that I had zero fuel pressure at the inline gauge right before the 10 Micron filter right before the throttle body. I assumed the filter was clogged, so I removed it. The fuel pressure was back and the engine started right up. This seemed to solve it until the engine was hot again (189deg max all day long) and it stalled or I shut it off. Same problem, no fuel pressure = no start.
So clearly it was cracking the lines and letting the vapor out, not the filter.
So I ran the rest of the day this way, if it shut off, I would just crack the line, let the vapor push the fuel back out, then it started no problem. Every time.
I am running 2000 5.0, with FiTech- ECU run timing, a G-Surge with a fresh Bosch intank pump, fed by a manual pump. I have the fuel returning from the throttle body to the accumulator and back to the tank. My tank is vented but gas always had pressure problems, if the tank is filled, it will push back out the cap. So I keep it roughly 3/4 full max (23 gallon BCB tank).
Since the trip, after lots of research, I came across information about the one way check valves throughout modern fuel injected vehicles. So I added one inline after the pump. Did some testing and it seemed like it would only hold pressure for a few minutes. I then decided to change the position of the check valve, removed 10 Micron filter, and then capped the return to the tank thinking that it contain any pressure bled off from the return system (I was assuming that the fuel was not leaking passed the injectors into the throttle body, because it always wanted fuel went it wouldn’t start), the results were identical. The gauge would go down to zero within 5 minutes or so, but if I cracked open a line fuel would shoot out?
I tried testing it by letting it idle and get up to 183 degrees (about as hot as it will get just idling still), shut it off, let it sit and heat soak and restart it. It did fine. I don’t trust it.
Clearly there is some manner of vapor locking going on, but maybe there is something off with the FiTech too? It was never this bad before. It’s 5 years old or so.
Any suggestions or thoughts?
Hh
Hh
