I recently lifted my Bronco from stock to 3" or so (old lift). At the time I did not realize I needed to mod the trac bar as well. Then I noticed the front axle sitting about and inch more towards the P-side. The Bronco rode Ok but I knew I shoudl fix it. So I got a drop trac bar bracket and installed. Now the Bronco wanders all over the road, especially at highway speeds. I have a 4 degree radius bushing kit that I am going to put in when I get the time. I realize it is a PIA of job. Could this be what is causing the wandering.
Also I had a few helpers when installing the drop trac bar bracket, my 5 yr old girl and 3 yr old boy were turning the steering wheel a bit when I was installing it, now the Ford symbol on the horn button is upside down (or as my 5 yr old says. "right side down".
Any ideas as to what is causing the wandering?
Will
Will
