Warn hub help
boogie
Lafayette La
I'm installing some Warn premium hubs on my bronco and I'm not sure if I need this ring? I don't see how it would fit anywhere
Timmy390
Conway, AR
That clip should go on the end of the axle sticking through the hub. If you push the axle out using a pry bar at the U joint, there should be a grove for that clip. The grove is maybe 1/4 to half inch from the end of the shaft.
Tim
savage
Bronco Nut
Renton
You can run with out it, some people put a big washer and bolt on the end of the axle, but you really don't need it.
DanHall
Pueblo, CO
I run without it. If I remember correctly they even tell you in the Warn documentation that you don't need it.
hubdawg
The axle will pull out enough to put the clip on just give it a little tug
DeezNCSU
I have the WH disc swap with Chevy spindles and run those hubs without the clip or bolt and washer... No problems so far.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Won't fit with the chevy disc conversion no matter how hard you pry on the axle. Use the outer snap ring and call it good. If you want to use a washer and bolt in the end of the axle for peace of mind, some do. I've run with just the outer snap ring for years.
TN1776
There are longer outer shafts available that allow the clip to be run with the Chevy brake conversion - mine has them and I run the clips.
Technically they are not needed but I see that your outers are drilled and tapped to accept a bolt. I would do that... bolt and a fender washer.
cekautsky
Alta Loma, CA
Just curious question here as i am about to install a set of the same locking hubs on my D44 with a chevy disc conversion. What keeps the axle from walking in and out of the diff if you don't run the clip or the alternate bolt/washer? It just seem that if the axle moves too far either way (in or out) that it could be an issue.
thegreatjustino
Stockton, CA
What would prevent the axle from walking out even with the snap ring or bolt and washer? They would only prevent it from walking in.
Spindle and the outer snap ring keep everything in place. The axle can only go so far into the differential to begin with. You're talking about fractions of an inch of movement.
