Bronco Beau
For Christmas I received the Trac bar riser and drop pitman. I was assuming I would need these before I finished my 3.5 lift. I just hooked the steering up and the drag link and trac bar are at the exact same angle. The riser and drop arm is supposed to correct this right? Well if it already looks parallel is there any advantage to installing either of these parts. Obviously to stay parallel i would have to install them both. Since it was such a small lift the axle still looks good left to right.
Will it increase my down travel or help me limit my up travel?
Will not installing them put more strain on my suspension?
Any help would be appreciated. I wanting this thing to have tons of droop and little up travel. Large tires and little lift = lots of ground clearance and low center of gravity.
Thanks alot,
Thanks alot,
