What have you done to your Bronco today?
sriha
Took a break from my other hobbies to put some time in working on the Bronco. Cleaned up the transmission cooler lines, one will probably work, will have to make one for the other side. Scratched the head where to put a filter for the transmission, probably will go under the battery tray but need to purchase the filter head. Couldn't go any farther on that so changed out the speedo cable. Found that over time many other wires were shoved through the hole that I needed to get the nut through so spend time chasing wires and relocating the ones I could. Eventually had to cut a wire to get the old speedo cable out. Finally got the other one installed. In the process I determined it was time to redo the wiring for the Bronco. Snowball time. Maybe it will be done by fall...%)
T-Bird
East TN
Found a pair of consecutive 66 plates to go on my consecutive VIN 66 broncos
fordfan
Are they '66s too.. the tags? You know Terry, you are lucky enough you should hold out for consecutive tags with the last four digits the same numbers of your consecutive vin numbered Broncos! A guy with your luck could probably find them!;D;D;D
T-Bird
East TN
Believe me Dennis I'm looking...
Z Bronco
Replaced a missing bolt that held the passenger Beard seat to its tracks, seat is no longer feeling like an ejection seat.
tasker
all knowing of nothing
NH
CRIED when I saw that it used to look good and just beat down now, but at least it is well used! ;D
JefeAZ
Tucson
Doors and mirror on! Satin silver from Toms
Comemonday71
Installed new tinted windshield and new seal....I can see clearly now that the pits are gone!
Remos69
SW Florida
The tub is finally under paint!!! Back on the frame next week to assemble the rest of the body and the remainder of the fun to begin!
