This is what I did and the only thing I am not happy with is I have more overdrive than I can use with the stock 3.5:1 rear and 31" tires. At 50 mph I can lug 1300 rpms.
98 Explorer 5.0 4wd - took the 4R70W, converter, front driveshaft, transmission wiring bundle, trans mount, dipstick, cooler lines
80's era NP205 iron transfer case - this thing weighs 150 pounds!!
NP205 bolts up to the 4R70W after you cut off a notch which you can see when you try to marry them up. No need to buy any adapters or take the transmission apart!
Built a new crossmember using the old frame brackets and 2" square tube to mount the transmission
Built a bracket and biscuit to support the NP205 using on body mount cushion
Changed the yoke on front of NP205 to match Explorer front driveshaft and had Explorer driveshaft shortened (my old front shaft was too short)
Shortened rear driveshaft
Bent new cooler lines needed an adaptor to go into radiator (trans is metric, radiator is not)
Bought Microsquirt controller and generic wire harness from DIY autotune
Created a simple wire loom using generic hardness and Explorer trans wiring bundle - shifter quadrant and main plug is all there is
I had MegaSquirt controlling my engine so I grabbed TPS from that for trans control. (If you do not have that you will need to pick up TPS for any solution using 4R70W)
Downloaded a tune and installed into Microsquirt -
https://www.msextra.com/product-range/expansion/microsquirt-transmission-control/
That had me up and running. I drove it around on the out of the box transmission tune for a while then made changes to shift points and firmness.
I did also had to re-route my exhaust for clearance.
After front disc and EFI this is the best mod. I seriously doubt a 289/302 can make enough torque to hurt either component. Plus they do not leak which is way ahead of the C4 I took out.
