what trans do i need
bowhunter1331
my head is spinning reading all these threads. Its so valuable but i guess I cant comprehend anything anymore.
looks like a AODE / 4r70W is my best bet... Does the 4R70 need to be from a 4x4?
i know i need to modify both of them and buy some aftermarket part.
is it simpler to just us a AOD and have it machined for the transfer case adapter?
Skip the AOD gearset, the ratios are not a good choice.
Several ways of doing it. Different adapter options. Even different transfer case options. A 2wd transmission can work. The transmission itself is the same, just the output shaft and tail housing are different. Output shaft takes a rebuild to replace. But can be shortened while installed. Replace when the spline count changes.
904Bronco
San Martin, CA
4R70W is the way to go, you will need a controller ($800-$1000) for it. A core (meaning needing a rebuild) on average is $300-$350.00
Two kits available for it from AA to adapt it to a Dana 20 T-case.
One is for the 4x4 case and makes the assembly 3" longer than factory. (The bonus is if the 4x unit is known to be good, then you don't have to go into it) But as Broncobowsher has stated other mods need to be done.
The other is for 2wd case and requires the output shaft to be changed out. It makes the assembly 1.5" longer than stock. (AA will tell you this is the best way to go on the phone). This same kit can be used on the 4x4 case.
If you have the JBA headers that WH's sells, the collector positioning on the Passenger side (a butt hair away from the bell housing) affects the dipstick tube/cooling lines positioning. FYI...
B
bowhunter1331
ok 4R70 prefferably from 4x4 with a 5.0 eng. not a 4.6 get output shaft shortened and buy an adapter adapter.. 96 or newer on a 4r70W..
ok the hunt is on!!! thank you 904 and Broncobowsher
'98 and newer have some nice upgrades inside.
The 3.8 mustang and 4.2 F150 V6 will also work, just not the flexplate. The V6 balance factor is different than the V8.
If looking at EFI, some of them (aftermarket) will support transmission as well. It may be a better value to step up a level on EFI to get transmission control than to run a seperate trans controller.
pcf_mark
This is what I did and the only thing I am not happy with is I have more overdrive than I can use with the stock 3.5:1 rear and 31" tires. At 50 mph I can lug 1300 rpms.
98 Explorer 5.0 4wd - took the 4R70W, converter, front driveshaft, transmission wiring bundle, trans mount, dipstick, cooler lines
80's era NP205 iron transfer case - this thing weighs 150 pounds!!
NP205 bolts up to the 4R70W after you cut off a notch which you can see when you try to marry them up. No need to buy any adapters or take the transmission apart!
Built a new crossmember using the old frame brackets and 2" square tube to mount the transmission
Built a bracket and biscuit to support the NP205 using on body mount cushion
Changed the yoke on front of NP205 to match Explorer front driveshaft and had Explorer driveshaft shortened (my old front shaft was too short)
Shortened rear driveshaft
Bent new cooler lines needed an adaptor to go into radiator (trans is metric, radiator is not)
Bought Microsquirt controller and generic wire harness from DIY autotune
Created a simple wire loom using generic hardness and Explorer trans wiring bundle - shifter quadrant and main plug is all there is
I had MegaSquirt controlling my engine so I grabbed TPS from that for trans control. (If you do not have that you will need to pick up TPS for any solution using 4R70W)
Downloaded a tune and installed into Microsquirt - https://www.msextra.com/product-range/expansion/microsquirt-transmission-control/
That had me up and running. I drove it around on the out of the box transmission tune for a while then made changes to shift points and firmness.
I did also had to re-route my exhaust for clearance.
After front disc and EFI this is the best mod. I seriously doubt a 289/302 can make enough torque to hurt either component. Plus they do not leak which is way ahead of the C4 I took out.
rjrobin2002
I always get a 4x4 96-2000 5.0 explorer one and adapt to the dana 20. The NP 205 is huge and heavy.
No need to take the 4x4 trans apart to change the tailshaft. I got mine off car-parts.com and had it shipped to my door and have also pulled one from a junkyard. If the fluid is still red and clear it's 99% of the time still good, if the fluid is black and burnt looking it needs a rebuild.
rjrobin2002
The 4x4 6r80 trans is 10 times better and easier to find, but will cost you more money. There are some threads on here where people use adapter kits to match them to ford small blocks and you get better first gear and 6 gears.
fordguy
So the AWD trans uses an adapter ring for Dana 20 and you keep the tail shaft as is? Atlas and np205 bolt to AWD. I mocked a AWD and np205 but changed my mind in the np205. What is your budget?
rjrobin2002
I used this on the back of my 4x4 4r70w 10 years ago I'm 99% sure. Search zf adapter on 4r70w on here, I followed someone's else's thread.
Grey owl
I went with a C4 and a Hughes converter, parts are easiy available, no fabrication required. Its a nice simple reliable but strong trans.
I have a little more time to type now...
The AOD, the ratios suck. 2.4 first and .667 overdrive needs really deep axle gears to work good. The mechanical governor and throttle valve inputs to control shifting are very limiting. Lacks 2nd gear hold. The convertor lockup logic isn't good. This is the only transmission that was ever done this way. Was revolutionary when new, and has evolved into something better.
The 4R70W is the updated and improved version of the AOD. The wide ratio gear set keeps the axle ratios from needing to be so low. Still needs to be low, just not as low. The torque convertor lockup logic is now selectable. Where the AOD had a bypass for the convertor in OD that never allowed slip, the 4R70W can unlock the convertor in OD. It can also lock it in other gears. The convertor lockup can be like an extra gear at times. Unlock in OD for a little extra RPM that doesn't call for a downshift to 3rd. Or lock when the convertor slip isn't needed. The computer to set shift points, all of them. You are not limited to living with what the factory tuning was like the AOD. Some real easy tuning and you can change the shift points to match your vehicle and your personal tastes. That off idle 3-4 upshift is slightly late? You can move that one single point and not mess with anything else. I really wish it would downshift on this grade without having to bury my foot so deep in the throttle, the losing speed on a grade and when you get in it enough to downshift it takes off like a rocket syndrome. Go in and change that part throttle downshift point. Stuff not conceivable with an AOD. And can be done without even getting your fingers dirty.
Already noted there are 2 different cases. The small block and the modular patterns. The small block is also known as the 2-bolt starter and the modular is the 3-bolt starter. They are the bolt pattern to mate to the different engine families. Already mentioned you need the 2-bolt, also used in some V6 applications (just the 3.8 in cars and 4.2 in trucks).
The output shaft and tailhousing in 2WD applications comes in 4 versions if I recall correctly, but that doesn't matter to you since you are looking for 4WD. The 4WD tailhousing and output shaft only come in one version (that I know of). It is the big 6-bolt pattern and 31-spline output shaft. It is the normal full size truck pattern used for decades. From the 70s until, well I don't know, I bet they still use it in some application.
The Bronco is a unicorn small 6-bolt pattern and 28-spline. This is where the ZF adapter was born. To make the ZF 5-speed transmission to the Bronco transfer case. Then it was fount to just be a universal adapter for the Bronco transfer case to any of the full size transmissions. Used with the Mazda 5-speed as well. And fits the 4WD version of the 4R70W. Now you can just bolt stuff together.
Before the ZF adapter, there was the new output shaft and tailhousing option. This uses a 27 spline transmission output shaft. It is unique to this adapter and has a matching transfer case input. As noted above, about 1½" shorter than using the ZF adapter. And with a Bronco being a short wheelbase and struggling for a decent rear driveshaft length/angle/slip travel that 1½" can matter. The thing is that new output shaft is installed in the transmission from the front. You have to rebuild the transmission. The very first part you install in the case is the rear output shaft. Mandatory rebuild. But this also opens the choices to more transmissions. Since you are not limited to only looking for a 4WD version. And it doesn't matter which output shaft on a 2WD either. Any of them will work. Because you are not using those parts. If you are going to build a transmission, this is what I would recommend. Fewer stacked parts, fewer stacked tolerances. A little better rear driveshaft. Also like the idea of just getting a good used 4WD transmission and bolting a transfer case to the back of it and running it without doing any rebuilding.
I was only looking at the options from the OP's list. The C4 is a simple bolt in option. But also a bit lacking. It is a basic 3-speed automatic. The gearing is very limited. Same as the AOD but without overdrive or any convertor lockup. It is the simpilist automatic swap. If you want the easy way out with the least performance, this will do. I still remember stories of when Stroppe was doing C4 conversions and customers where actually going back and having the automatic removed and the factory 3-speed put back in.
The 6R80 is another great option. This is one of those just bolt a good used one in (adapters at both ends) and no rebuild needed. I would do this if I were doing another swap. I think it is great. I've driven the transmissions, they are good. I have seen one at work take a beating in an F150 with a blower turned up to max. Blew both the rear end and the engine at different times. Drag racing on slicks. He did go through the transmission as he rebuilt the engine (to fix the damage and make more power). I have some respect for what that transmission can take in stock form. I just have zero experience swapping them.
B
bowhunter1331
Thanks for all the info. looks like the adaptors cost more than a 6R80. then add a tuner.. i saw one for a carb and i think i will upgrade to efi.. thanks again to all
B
bowhunter1331
for clarification, if i buy or find a good 4r70w all i need is the 2 adaptors, (adapt to sbf & adapt the Dana 20) + a controller
rjrobin2002
That's the key to getting one out of a v8 96-2000 4x4 explorer, it was already bolted to a small block ford.
I pukk them together and use the explorer motor and trans and adapt the 4x4 tailshaft to the dana 20.
B
bowhunter1331
No. Only the transmission to the transfer case.
The engine will bolt directly to a 4R70W
The engine to transmission adapter is only needed with the 6R80
I have my transmission guy looking for a unit right now. He mentioned the flex plate that I might need to change it. Is that accurate or if I get one from 96 to 2000 it should bolt right up
You need to know what the original balance to your engine is. The original 302 is 28.8 and after '82 it went to 50.2
The 351 AOD combo is the right flexplate for an early 302. The factory Explorer is right for a late 302.
Do NOT get a flexplate from a 351 E4OD or C6. They match all the diminsions, except the convertor mounting depth. It will bottom out the convertor into the transmission and the crank into the thrust bearing, both bad things.
C4, AOD, 4R70W flexplate good depth
C6 E4OD flexplate bad depth.
You need 164 tooth, 11.4" convertor bolt circle.
PNW
bowhunter.... do this right if buying a 4r70w and get the Sept & later 4r70W. The late '97 and later had upgrades of solenoid, internal wiring, one way clutch, sprag, etc) that Ford needed to upgrade them so why buy the early trans that needed updates? Also, if you buy the '96-97 models you need to change a couple wires on the controller because of the internal wiring of those two years. Tell your mechanic guy you ONLY want the '98 or later model.
If you go the 6r80 route you will never regret it. I used to build adapters for them to install in our Broncos and their gear ratios, durability and everything about the newer auto (over C4 and early autos) has features you will appreciate every time you drive it. I wrote a tech article here on CB that explains nuances for this install and the adapter style is now outdated as my last updated design is exactly what Josh is now producing albeit with a proprietary starter tho. Might check the write up out as it's got a ton of 6r info if you go that route. Super low first gear and 2 OD ratios fill the need for slow crawling and street cruising.
