clintonvillian
How much lift, or hood bracing/removal or scoop is required to get a stock 5.8 EFI system to fit?
Just to be sure we're all on the same page, are you talking about using the full 5.8 EFI system out of a truck? Or will you be doing the usual modifications to the induction system to make it work far easier.How much lift, or hood bracing/removal or scoop is required to get a stock 5.8 EFI system to fit?
Oh .... I could make it fit...practicality is another question.Just to be sure we're all on the same page, are you talking about using the full 5.8 EFI system out of a truck? Or will you be doing the usual modifications to the induction system to make it work far easier.
If talking about a full 5.8 truck EFI setup I'll go out on a limb to say that you can't get there from here. At least not if you have to ask if it can be done...
Of course, it "can be done" and some have done it. But not without extensive modification to the hood. Even with a 3" body lift you still have to modify the hood.
Last one I remember seeing pictures of simply cut a nice clean hole in the hood and let the intake plenum stick out the top.
nope. Aftermarket uppers are your only option.Could an efi intake from a 5.0 be swapped over?
https://www.pricemotorsport.com/html/body_intake_adapters.htmlnope. Aftermarket uppers are your only option.
I am willing to go full aftermarket...and that's why I'm here asking the questions.Double check that 2WD transmission. A '91 F150 with a 351 should have an E4OD if Overdrive, maybe just a C6. Those would be a tough fit into a '66 Mustang.
BC once had an adaptor that would let you bolt a 5.0 mustang (the one that doesn't flow that good) onto a truck lower. Made for a running engine. As long as you were not asking for performance out of the package it should be a runner. Just don't count on a performer. That upper is a bit restrictive on a 5.0 and even more so on a 5.8 with extra choke points for the adaptor.
You do know that the EFI is just an add on to a regular 351 engine? You can toss all that truck EFI stuff and just use a regular intake/carb/ignition. That can fit. With just the right parts it can even fit under a stock hood without a body lift.
Is that Trick flow shorter?Bluntly if you want to make more (as opposed to less) power than a 5.0 (also known as a 302) adapters to fit a constrictive 302 intake onto a 351W aren't helpful.
It's too bad that the aftermarket hasn't stepped up to clone the infamous "Lightning lower" intake. One of those plus your choice of uppers, Cobra, GT-40, Explorer 5.0 (pick one, they are all close flow-wise) works pretty well for a 351Wf especially if you aren't drag racing. but good luck finding one for a not-insane price.
And then there is full aftermarket. I have a Trick Flow R lower and upper on my 408 stroker. I waited months for those parts. Good luck finding that combo right now, for reasons I don't understand. Edelbrock has made a similar combo. But same problem. Back-ordered into the next decade unless you can find used parts.
I forgot about those....and been using Price adapters for other stuff for years. LOL..good catch. Not the best option..but an option at least.https://www.pricemotorsport.com/html/body_intake_adapters.html
Those are interesting...they are to adapt intakes from. The 302 to the 351.
Or these....https://bcbroncos.com/shop/fuel/efi/11-82010-efi-manifold-adapter-351302-for-early-bronco/
The opposite. It's not as tall as the 351W truck manifold but it sticks up pretty high. Photos below are of my old Explorer 5.0 and my current 408, with a Trick Flow R intake. The old engine fit under my stock hood with an old school 1" (actual 3/4") body lift. To clear the new engine I needed a true 1" body lift and a Wild Horses "Highlander" hood. Even then it barely fits. The contortion in the intake tract is to snake it down under the right side of the hood.Is that Trick flow shorter?
I just looked on Ebay. That's on the low side- one is listed for $1650. Trick Flow has a few of my R upper intake but they don't even show a listing for the lower, though there is one on Ebay for $900. Edelbrock is out of stock on theirs.You see the lightning lower intakes pop up but going price is about 1k.
No. The Trick Flow R upper requires a Trick Flow R lower.So…the trick flo goes on top the truck lower?
