When is it no longer Ford Powered?
jamesroney
Fremont, CA
What we have here are two perfect examples of rational thinking:
You guys are enlightened. You two are perfect examples of exercising vehicular passion that has not been muddied by emotions.
Im on board! As long as we all realize that the opinions posted regarding bell housing pattern compatibility are not relevant to the topic.
Chevy Bell housing patterns being unchanged for 60 years is not interesting from the perspective of re-powering a Bronco. Bronco's do not care if your 2005 LS motor will bolt to your 1967 Turbo 350. Neither will bolt to a Dana 20. The rest of the story is that there are dozens of different bell housings, half a dozen flywheels, multiple transmission index diameters, and the entire BOP incompatibility issue. Couple that with the oddball AMC Turbo 400 bell patterns, and from 1966-2001...(2020 for crate motors...) you actually have the same number of bell patterns for SBC and SBF. (exactly 1)
That's right. For 54 years, one pattern for the Small Block Chevy, and one pattern for the Small Block Ford.
So I will agree that a single bell pattern is a great argument for replacing a Chevy with a different Chevy. Unless you own a Buick, Oldsmobile, or Pontiac. Or is a Pontiac not a Chevy? Unless it shipped with a Chevy engine. Is GM still paying out on that lawsuit?
Box stock,and without enhancements...From 1965 to 2006 I can't think of any RWD GM transmission that is superior to its Ford counterpart. (not counting the previously mentioned E4OD) So why would I want a Chevy pattern bell housing?
C4 vs TH350 = same.
C6 vs TH400 = same.
AOD vs 700R4 = both junk
AODE vs 4L60E = still junk
E4OD vs 4L80E = gotta go GM
4R100 vs Allison 1000 = ugh. GM again.
RAT/RAN vs Muncie 3 speed = same
HEH/RUG vs Muncie M21, M22, and any T10 = Ford
T18 / T19 / NP435 vs SM420 / SM465 = same
M5OD vs NV3500 = yuck
ZF-S42/S47 vs NV4500 = same
T5 vs T5 = more junk
T56 vs T56 = seeing a pattern here.
TR3550 vs ??? = Ford by TKO!
ZF-6 vs UH-OH...no GM manual transmission
Since 2006, (that's 14 years!!!) GM has not put a manual transmission in their HD pickup truck. So why exactly do you still want a Chevy pattern bell? To bolt to the non-existent GM transmission? Now you are adapting back to something that isn't Chevy. So you need to find a better reason. You were doing great with:
A. Rear sump oil pan.
B. Cheap.
I like emotion...
nvrstuk
PNW
I looked at Tigers too long... and the price went out of my price range...thats3my 2nd pic behind an AC Cobra... guess I do like those Fords!! )
gmduncan
Annapolis
The answer to this thread is based on opinions and one look at my user name will establish by bias.
Anyway, this is my opinion: The 'heart' of the Bronco really is the engine. It's what puts 'life' or motion, or movement to make a Bronco do what a Bronco does. When the 'heart' of the Bronco is transplanted for a competitive brand, to me, it isn't a Bronco! I can't look at a Bronco with appreciation if it doesn't have a Ford 'heart'. The same with a Chevy with a Ford engine, I just can't appreciate it! They are just 'bastards'....a mixed breed of a combination of parts. I can appreciate looking at a Bronco with any Ford heart, but I like them better if it is a period correct Ford engine... or appears to be. Yes, I agree that the Coyote engine swaps doesn't do a thing for me. If you want a Coyote, buy a Mustang or a new F150... BUT.... This is just my OPINION!;D;D;D
Couldn't agree more!
jamesroney
Fremont, CA
So Ford put a VG30 and VG33 in the Mercury Villagers built in Avon Lake Ohio, the same plant they built Econolines at for decades. Does that mean I can put a VG30 out of a 300Z or a VG33 out of an Xterra in a Bronco and still call it "powered by Ford"? It was an engine Ford put in vehicles they sold hear in the states.
asking for a friend, not myself.
Too funny! Thanks.
I didn't know that Ford was putting Datsun Motors in their minivans. So the short answer is "yes." You can put a minivan VG30 or a VG33 your Bronco and still call it "Powered by Ford." If you stack them, you might even be able to fit them both. (...in the bed!)
Minivan motor in a Bronco? How bad can that be? Let's ask the boys in Toledo how bad it failed in the JK. Or just look at the price difference between a 2011, and a 2012.
On a Side note:
In 1967, Chrysler finalized the acquisition of Rootes Group and contineud to produce the Sunbeam Tiger. The Sunbeam Tiger was made by Chrysler, but "powered by ford." Does this means that the 1967 Ford 289-V8 became a Chrysler??? I once took a 67 Ford 289-V8 and transplanted it into a Bronco. It was the best (and cheapest) Mopar conversion that I've ever done.
I knew about the Chrysler owned Sunbeam powered by Ford. The Chrysler engineers couldn't figure how to put there engine in place of the Ford. Lasted 1 year if I remember correctly.
No Hay
I am sure that is true, however that only applies if the rodder in question happens to know anything about chevy engines, and is willing to even consider using one of them. I have never swapped a chevy engine or transmission in my life, but I have swapped many ford engines and transmissions. I know Fords, and I am comfortable with them. I know nothing about chevy engines and have no real desire to learn. I am pretty sure I am not alone in that. now if someone wanted to contaminate me by giving me a 67 corvette I would reconsider lol.
"contaminate"? In this day and age, there must be a lotion for that.
I drove this '67 over ten years recently with no ill effects. Though it was a small block ;D
mustanggarage
see, now I am pretty confident I could work through any residual effects with one of those ;D;D
It might be called "sweet revenge"?
But perhaps not a reasonable comparison though, since a Ferrari is typically also a vehicle that lives, eats and breathes it's ultimate value on originality over all. And with most Ferarris (but perhaps not all?) there's not much reason to break a sweat over finding a suitable non-Ferarri donor engine.
Probably deeper thinking people can figure out reasons for and against, but those are my simple thoughts on the Ferrari vs Ford matter.
sprdv1
REBEL
pretty sweet ride.. :)
jamesroney
Fremont, CA
So how do you feel about taking a Ferrari and putting a Ford V8 in it?
Asked and answered in Post #24.
Rule #1 "The replacement part must be superior to the existing part."
Rule #2: "The replacement part must be superior to alternative replacements."
A small block ford in a Ferrari is not "better." This makes it "worse."
Yeller
Rogers County Oklahoma
Bring it over ;D
Even I have my limits, there has to be at least some legitimate reasoning, at that point (depending on the Ferrari) I’d say build a kit car. I do feel I can say most everything that I’ve bastardized was destined for the crusher and was saved from that fate. All except the factory big block Malibu that I put 513ci BB Ford in:p it was a purdy car that had a bit too much nitrous with a failed fuel pump, it was Friday and we had a race on Saturday, still won our grudge match;D
Rustytruck
I like them with a distributor in the front. Why anyone with a right mind would put them in the back where you cant get to them is nuts. Just as long as you paint what ever you put in ford blue your good to go.
nvrstuk
PNW
...I like 'em without a distributor! ;)
OX1
Because an LS swap is easy and cheap, it's everywhere. I see them all over @ the shows, but not much to talk about, could have the exact same conversation with 20 different guys.
Now the 430 in my 59 bird, many never even heard of it before. Of course an FE (the other engine that came in a 59 bird) would be easier to build and put out more power. But not as unique.
I also like owning Fords since it's harder to keep them up (and cost more with many times harder to find parts, not so much on EB's of course). They are a PIA with all the different engines, bellhousings, and even wiring. That's what makes it fun.
